Use this guide to remove or to replace a worn-out or dead battery in your Fairphone 3.
If your battery is swollen, take appropriate precautions.
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
Pry the back cover up to start separating its plastic clips.
Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
Lift the back cover to release the rest of the plastic clips and remove it.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Lever the battery up until you can get a good grip.
Lift the battery out of its recess and remove it.
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
crwdns2935229:016crwdne2935229:0
Vielen Dank!
Einfach und direkt umgesetzt..
Imagine if all cellphone producers made it this easy :-)
Anything to keep in mind, e.g. should I first give the phone a full charge once the new battery is installed?
Where can I get the battery in Nigeria, if not how can I get one coz the one on my phone is weak
