Edifier W820NB Plus Motherboard Replacement
  1. Edifier W820NB Plus Motherboard Replacement, Ear Pads: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start with the headphones face up and the earpads visible.
  2. Edifier W820NB Plus Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Edifier W820NB Plus Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the driver housing in one hand and insert an opening tool into the seam between the earpad and driver housing.
  3. Edifier W820NB Plus Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Edifier W820NB Plus Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With your inserted opening tool, pry around the perimeter of the ear pad until it fully releases.
    • Repeat this procedure for the other side if necessary.
  4. Edifier W820NB Plus Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat for the other side if necessary.
  5. Edifier W820NB Plus Motherboard Replacement, Drivers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Identify the driver you wish to replace.
    • This guide will use the left driver as an example but the same steps can be mirrored when replacing or removing the right driver. The battery is under the left driver, while the motherboard and daughterboard are under the right driver.
  6. Edifier W820NB Plus Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Edifier W820NB Plus Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all five 5 mm Phillips #0 screws that secure the driver assembly.
  7. Edifier W820NB Plus Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Edifier W820NB Plus Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Edifier W820NB Plus Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Note that the wires for the drivers are on the outermost edge. Try to avoid pushing or cutting them when taking the driver out.
    • Insert a Jimmy in the seam between the driver assembly and driver housing.
    • Rotate the Jimmy along the entire perimeter of the innermost edge to pry it out of place.
  8. Edifier W820NB Plus Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Edifier W820NB Plus Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the driver assembly from the rest of the headphone, with care not to strain the connected wire.
  9. Edifier W820NB Plus Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Edifier W820NB Plus Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Skip this step if you are completing a battery replacement.
    • Repeat the procedure for the other driver if necessary.
    • Desolder the four driver connections from the motherboard.
    • Remove the driver assembly.
  10. Edifier W820NB Plus Motherboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Edifier W820NB Plus Motherboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the black strip stuck to the top of the motherboard.
  11. Edifier W820NB Plus Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Edifier W820NB Plus Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Edifier W820NB Plus Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 2 mm screws that secure the motherboard with a Phillips #0 screwdriver.
  12. Edifier W820NB Plus Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Edifier W820NB Plus Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the motherboard out.
    • Desolder all motherboard connections.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Happy Zhang
crwdns2935283:003/21/25crwdne2935283:0
438 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-7, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 2-7, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S2G7
crwdns2942667:0crwdne2942667:0 151
