Eco X Gear Battery Replacement
crwdns2942287:0crwdne2942287:0You will need a phillips head screw driver, flat head screw driver, and needle nose pliers to complete this task. Before opening the device, ensure that there is no power to avoid damaging the electronics or harming yourself.
crwdns2944105:0crwdne2944105:0
Disconnect any power source and/or turn off device.
Remove the 15 rubber plugs from the cavities using needle nose pliers.
Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
Carefully separate the two sections of the frame.
Disconnect the wiring to improve accessibility to the battery.
Remove the two screws that hold that bracket, securing the battery in place.
Disconnect the wires that hold the batteries down to the motherboard.
Pry the battery from the frame using your hands or an opening pick.
When removing and installing the battery, be cautious to not damage any of the surrounding electronics.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:03crwdne2947412:0
Where to get the new battery?
Hello EcoXGear lovers, i just bought this battery from amazon yesterday and perfect fit with polarity you can get the battery here
