EasySMX ESM-9100 Joystick Replacement
  1. EasySMX ESM-9100 Joystick Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the controller face down on a solid surface.
    • Use a Phillips #00 screwdriver to remove the seven 10 mm screws from the back cover.
    • The order does not matter.
  2. EasySMX ESM-9100 Joystick Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EasySMX ESM-9100 Joystick Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EasySMX ESM-9100 Joystick Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the iFixit opening tool to pry off the back cover and remove it to reveal the internal components.
    • Place the cover off to the side, then grab the circuit board and gently remove it from the front cover.
    • Be careful when removing the back cover, the components in this controller are loosely attached and can fall out easily.
  3. EasySMX ESM-9100 Joystick Replacement, Joystick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EasySMX ESM-9100 Joystick Replacement, Joystick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly pull off the two analog sticks (joysticks) from the potentiometers.
    • Be careful when removing the analog sticks as excessive force can cause damage to the potentiometer.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Alex Vala
crwdns2935283:003/19/24crwdne2935283:0
822 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-4, Shaddix Spring 2024 crwdns2935289:0UMass Dartmouth, Team 4-4, Shaddix Spring 2024crwdne2935289:0
UMASSD-SHADDIX-S24S4G4
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 640
