EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement
  1. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Chock the wheels: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Chock the wheels: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, ensure the machine is powered down and cool to the touch.
    • Chock the wheels to prevent the machine from moving while you are working on it.
  2. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Turn off the ignition switches: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Turn off the ignition switches: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Turn off the ignition switches: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the ignition switches on the motor and the handle bar into their "OFF" positions.
  3. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Close the fuel valve: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Close the fuel valve: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the fuel cutoff valve switch into the off position.
  4. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Disconnect the spark plug: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Disconnect the spark plug: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  5. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Remove the air cleaner cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Remove the air cleaner cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Remove the air cleaner cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the wing nut on top of the air cleaner cover.
  6. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the air cleaner cover.
    • This will make it easier to reach the throttle cable holder with a screwdriver.
  7. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Remove the throttle cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Remove the throttle cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a short Phillips screwdriver to remove the screw securing the throttle cable holder.
  8. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the throttle cable up to a vertical position and pull it straight up to remove it from the throttle control lever.
  9. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Remove the throttle control assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Remove the throttle control assembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the black throttle control knob and pull it straight up and off of the control lever to remove it.
  10. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 7/16 inch socket with a 3/8 inch wrench to remove the two bolts and accompanying nuts securing the throttle control assembly from the handlebar.
  11. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the throttle control assembly.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
90,819 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 396
