EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement
  1. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Chock the wheels: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Chock the wheels: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, ensure the machine is powered down and cool to the touch.
    • Chock the wheels to prevent the machine from moving while you are working on it.
  2. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Turn off the ignition switches: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Turn off the ignition switches: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Turn off the ignition switches: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the ignition switches on the motor and the handle bar into their "OFF" positions.
  3. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Close the fuel valve: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Close the fuel valve: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the fuel cutoff valve switch into the off position.
  4. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Disconnect the spark plug: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Disconnect the spark plug: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  5. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the belt guard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 9/16 inch socket to remove the two bolts securing the belt guard to the main frame.
  6. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the belt guard.
  7. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Loosen the belt-tensioner lock nut: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 9/16 inch wrench to loosen the lock nut on the belt-tensioner bolt.
  8. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your finger to spin the lock nut counterclockwise until there is a about a one inch gap between it and the frame.
    • Wrap a piece of tape around the belt-tensioner bolt where it meets the frame.
    • During reassembly, tighten the belt-tensioner bolt until the tape is flush against the frame (or until the belt is sufficiently tensioned) and then tighten down the belt-tensioner lock nut to the frame.
  9. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the belt-tensioner bolt: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the belt-tensioner bolt: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the belt-tensioner bolt: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 9/16 inch socket to remove the belt-tensioner bolt from the frame.
  10. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Disconnect the ground wire: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 9/16 inch wrench to remove the nut securing the ground wire to the engine block.
  11. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ground wire and tooth washer from the engine mount.
  12. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Relieve tension on the bolts: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Relieve tension on the bolts: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 9/16 inch wrench to loosen the four nuts securing the engine block to the frame, two on the front and two on the back.
    • Do not completely remove these nuts.
  13. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the engine towards the front of the frame to relieve tension on the belts.
    • To keep the motor in the de-tensioned position, tighten a couple of the nuts down.
  14. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the belts from the motor pulley: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the belts from the motor pulley: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the belts from the motor pulley: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the outermost belt out of its pulley groove and rotate the motor pulley to remove it.
    • Repeat for the two remaining belts.
  15. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the cutter blade: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the cutter blade: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the guide bar onto the ground out of the way of the blade guard.
  16. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the blade guide straight up and off of the frame and place it next to the machine.
    • The blade guard is still attached to the device via the water hose.
  17. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When working with the blade, wear gloves. The edges of the blade are sharp. Be careful not to cut your arms on the blade.
    • Use the two included 1-1/2 inch wrenches to twist the arbor shaft nut counterclockwise while holding the backing plate in place.
  18. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the arbor shaft nut, lock washer, and blade cap from the arbor shaft.
  19. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the blade.
  20. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the arbor shaft: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the arbor shaft: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the arbor shaft: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the guide bar back up off the ground into its vertical position.
  21. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 9/16 inch socket to remove the four bolts securing the arbor shaft bearings to the frame.
    • If necessary, have a second person hold the arbor shaft to prevent it from hitting the ground.
  22. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the arbor shaft.
  23. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the belts: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the belts: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the belts from the arbor shaft pulley.
  24. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Mark the pulley location: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Mark the pulley location: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pen to mark the location of the pulley on the arbor shaft.
    • During reassembly, line the pulley up with this marking to ensure the belts are straight.
  25. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the arbor shaft pulley: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 5/32 inch hex key to loosen the two arbor shaft pulley set screws.
    • The set screws do not need to be completely removed.
  26. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the arbor shaft pulley.
    • Remove the shaft key.
  27. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Mark the bearing locations: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Mark the bearing locations: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pen to mark the locations of both of the arbor shaft pulleys.
    • During reassembly, slide the new bearings up to these marks to ensure they align with the mounting locations on the frame.
  28. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the left arbor shaft bearing: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/8 inch hex key to loosen the two set screws on the arbor shaft bearing opposite the backing plate.
    • During reassembly, do not tighten these set screws until the bearings have been secured to the frame to ensure proper alignment.
  29. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the left arbor shaft bearing.
  30. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement, Remove the right arbor shaft bearing: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/8 inch hex key to loosen the two set screws on the arbor shaft bearing next to the blade backing plate.
  31. EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EDCO PRO KL-18 Concrete Saw Arbor Shaft Bearings Replacement: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the right arbor shaft bearing.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
90,819 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2942667:0crwdne2942667:0 516
