DualShock 4 CHU-ZCT2U Joystick Covers Replacement
  1. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the rear panel screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the rear panel screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
    A driver size recommendation would be nice. I tried several and found that a size 2.5 Phillips worked nicely
    Justin Vander Ziel - crwdns2934203:0crwdne2934203:0
  2. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Separate the rear panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Separate the rear panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
    easy, but quite brute way of opening the rear panel without the opening tool: https://www.youtube.com/watch?v=wYybiBBL...
    watch the opening from the back part only, then return here.
    christianviali - crwdns2934203:0crwdne2934203:0
    That worked but a couple clips broke in the process. Beware for people trying this method.
    Bryan Remely -
    There are 4 tab clips total, 2 at the top corners (very easy to break) and 2 at the bottom near the ports. The screws will keep it together even if they do break but be careful if you don’t want to break them.
    Fungi -
    I've written a guide to help others find the clips and unlatch them.
    Important Step For Opening the DualShock 4 CUH-ZCT2U
    Richard - crwdns2934203:0crwdne2934203:0
    Hi Richard,
    Thanks for writing this up! I'm going to link your guide into the step.
    Arthur Shi -
  3. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Release the plastic clips: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Release the plastic clips: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Release the plastic clips: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
    I've written a guide to help others find and unlatch these clips
  4. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the rear panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the rear panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
    I'm struggling getting the ribbon to connect back in. Why might that be?
    David Clair II - crwdns2934203:0crwdne2934203:0
  6. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
  7. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery.
  8. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the 6.4 mm-long screw securing the battery bracket.
    On my model (CUH-ZCT2E, I guess E for European), the screw secures the mainboard, not the battery bracket. The bracket is secured by 2 clips on the top left and top right. They can be pushed slightly one-by-one to remove the bracket.
    Zinurist - crwdns2934203:0crwdne2934203:0
  9. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery bracket.
  10. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to disconnect the touch panel ribbon cable.
    • Pull the ribbon cable directly away from its connector on the motherboard by the blue pull tab, not by the cable itself.
    My tweezers stabbed the cable,yikes!
    jat xe mo - crwdns2934203:0crwdne2934203:0
    i cant plug the cable back in :)
    Antoniomastro10 - crwdns2934203:0crwdne2934203:0
    Can you plug the cable back in?
    LeBron James - crwdns2934203:0crwdne2934203:0
  11. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the motherboard and midframe assembly from the front panel.
    If you’re having trouble separating those part, this might be because of the blue pull tab. Make sure the pull tab is pushed through the hole to free the motherboard and the midframe assembly from the front panel.
    Philippe Morin - crwdns2934203:0crwdne2934203:0
  12. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the joystick covers: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the joystick covers: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the right joystick cover straight off the joystick module to remove it.
  13. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the left joystick cover straight off the joystick module to remove it.
  14. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Reassembly tip: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Reassembly tip: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly, ensure the new joystick covers properly align with the shafts on the joystick modules before pressing them into place.
crwdns2935229:035crwdne2935229:0
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
87,927 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
Are you able to replace the actual joystick with a diffrent one or are we only able to switch out covers?
Grant seward - crwdns2934203:0crwdne2934203:0
this is a good point, i was wondering this as well
Kyeler W -
crwdns2936751:024crwdne2936751:0 24
crwdns2936753:07crwdne2936753:0 120
crwdns2936753:030crwdne2936753:0 541
crwdns2942667:0crwdne2942667:0 25,207
