Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild
  1. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove manifold cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove manifold cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove manifold cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the power cord, depressurize the compressor tank, and remove any hoses before starting this repair.
    • Use a long-shank T10 driver to remove the manifold cover screw.
    • Lift the cover directly up off of the gauges to remove.
  2. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove regulator knob: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove regulator knob: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove regulator knob: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Twist the regulator control knob counterclockwise. When you feel resistance, continue to twist to break the knob free.
    • This may take a lot of force.
    • Remove the knob.
  3. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the spring from inside the regulator control knob.
  4. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove regulator internals: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove regulator internals: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove regulator internals: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use needle nose pliers to remove the fitting.
  5. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to unscrew the pressure regulator assembly from inside the manifold.
    • Use needle nose pliers to remove the regulator assembly.
  6. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Assemble new regulator internals: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Assemble new regulator internals: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The next three steps describe how to assemble the new regulator assembly.
    • Install the new o-ring on the new screw fitting by sliding it over the threads. Make sure it sits flush on the head of the screw fitting, directly above the threads.
    Q what is the role and procedure on the semi-circular spring? I have both kits,(-52, and -53) not sure if the original spring blew out, the original plastic tip of the round disc was damaged initially.
    mine is a CMEC6150 type 1 pancake ," proudly made in usa " Craftsman, 2019, and I will need to search if the original spring is "round" or "square"
    or still in its groove, ( if spring is there, does it need removal first ?..also wish for assembly diagram which craftsman doesn't seem to have on line, not all you tubers have the same exact design ,
    some even have a back entrance to load the small reg spring in .Otherwise, mine looks a lot like this demo. regulator in center, and 2 outlets on the right
    Cliff Stage - crwdns2934203:0crwdne2934203:0
  7. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Seat the narrow end of the new cap into one end of the new spring.
  8. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the cap and spring, cap first, into the opening on the screw fitting to complete the new regulator internals.
    • Reassembly tip: some of these components are not firmly attached to each other, so reinstall carefully, being sure everything lines up.
    How can I tell which repair kit to use? This part is too vague:
    “Use part numbers 5140147-52 or 5140147-53 depending on the manufacturing location.”
    Shawn Brown - crwdns2934203:0crwdne2934203:0
    Thanks! I used the instructions to repair a DWFP55130 compressor. I did not use the kit as they don’t have one for my compresssor. In my case, the small spring had completely corroded. I replaced it with a similar enough spring and it’s working great now!
    Imran Latif - crwdns2934203:0crwdne2934203:0
Carsten Frauenheim
145,310 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,464crwdne2935297:0
Perfecto... buena ilustracion y mejor explicación.Gracias.
Arturo - crwdns2934203:0crwdne2934203:0
Any instructions for the Type 2 regulator?
James Figuracion - crwdns2934203:0crwdne2934203:0
My regulator does not have a gauge. It only has a "min/max" knob. Will this kit work?
Vickie Hills - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 124
crwdns2942667:0crwdne2942667:0 4,957
