Delonghi 23.120 coffee machine shows the following symptoms:
- Not making any water pumping at boot
- Blinking steam button LED
- Impossible to perform any action, steam or coffee
This guide shows how to check all the elements from the coffee machine to isolate the firmware issue, and how to fix the firmware issue itself.
Put steam tap on 0
Plug the machine
Press and hold buttons "1 short coffee" and "steam" simultaneously
Switch the On/Off button on the back to 1
Release "1 coffee" and "steam" once the motor starts moving
Add water in the tank
Empty the water collection tray
Open the side panel to be able to see the infuser and its endless screw
See Step 1 from brewing group tutorial
Press the "1 long coffee" button
It should move the infuser part up to the max, then down
Press the "water drop" button
It should turn the grinder on
Press the "steam" button
It should turn on the water pump
Press the "P" button
It should heat up some water
Every element separately works, the issue is probably due to corrupt software
In order to reflash the software, first unmount the PCB from the machine
Follow step 1 to 6 from here: DeLonghi ECAM Series Leistungsplatine reparieren
The main microcontroller is a PIC18LF2520
It can be programmed via the pads at the side of the board
Numbered from 1 to 7
(1) nMCLR, (2) PGC, (3) PGD, (4) VDD 5V, (7) VSS GND
You need a programmer for Microchip PIC-8 series
Several models are available: PICKit, ICE, ICD, Snap
Solder a 7-pin 2.54mm header to the pads
Use jumper wires to connect to the programmer
If the programmer does not support it, connect an external 5V power supply to the microcontroller
An easy hack consists in using a USB connector: the red cable is 5V and the black is GND
Solder USB power lines to the pads (7) GND and (4) VDD
Plug in the USB connector to a main power adapter or a computer
Download and install the MPLab X software from Microchip website
Find a program hex file
Program for ECAM 23.120 SW2 can be downloaded from here
Other models can be found on this forum
It is also possible to copy the firmware from another coffee machine from the same model
Create a new project with "New project -> Prebuilt Project"
Select the firmware hex file
Select the PIC18LF2520 in the 8-bit PIC section
Go to "Window -> Target Memory View -> Program Memory" and click the "Read Device Memory" button. Verify it reads some bytes.
In the top menu, find the "Read Device Memory" button, click its drop-down arrow and select "Read Device Memory To File"
Click "Program Device for Production main Project" to flash the new program
Test the board before starting re-assembling
Replug all connectors
Try turning it on and brewing a coffee
The header connector pins can be left soldered, there is enough space to fit them
Re-assemble the machine
This machine had a screetching noise coming from the worm screw
Open the cache, remove the coffee infuser
Carefully drop some lubricant on the worm screw, at its top and bottom
