Dell XPS 13 9365 2-in-1 Display Assembly Replacement
  1. Dell XPS 13 9365 2-in-1 Display Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
    Keeps track of the screws is vital. Put screws together put in seperate piles for each level. You want to be able to put the same screw back in the same place, and the screws are small so easy to mess up.
    Alexander Wolf - crwdns2934203:0crwdne2934203:0
  2. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Display Assembly Replacement, Display Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x2.5) that secures the wireless-card bracket to the motherboard.
  9. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the wireless-card bracket off the wireless card.
  10. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of nylon tipped tweezers to gently disconnect the antenna cables from the wireless card.
  11. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the tape that secures the display cable to the M.2 solid-state drive heatsink.
  12. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x2.5) that secure the display cable bracket to the motherboard.
    • Lift the display cable bracket off the display cable.
  13. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the pull tab to disconnect the display cable from the motherboard.
  14. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the touch-screen cable from the system board (labeled "TS").
  15. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the camera cable from the system board.
  16. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the palm-rest assembly fully and place the display assembly and palm-rest assembly face down.
    • Make sure that your surface is flat and free of objects when you lay the laptop face down.
    • Use a Phillips #000 screwdriver to remove the six screws (M2.5x3.5) that secure the display hinges to the palm-rest assembly. There are three on each side.
  17. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the display assembly off the palm-rest assembly.
Melissa Schlein
crwdns2935283:003/21/22crwdne2935283:0
716 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 3-4, Bedsole Spring 2022 crwdns2935289:0University of Alabama, Team 3-4, Bedsole Spring 2022crwdne2935289:0
UA-BEDSOLE-S22S3G4
how to disassembly hinge for replace the video cable?
Logan Solo - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,054
