Dell OptiPlex GX260 RAM Replacement
Kevin Schapansky
crwdns2944107:0crwdnd2944107:0Kevin Schapanskycrwdnd2944107:0crwdnd2944107:0crwdnd2944107:08crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Huk 4, 2019crwdne2944111:0
crwdns2931287:05crwdne2931287:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
This computer can either use DDR 333 or DDR 400 memory, and can take up to 2GB of memory according to Dell
  1. Dell OptiPlex GX260 RAM Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell OptiPlex GX260 RAM Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
    cool de faires des sites comme ca :)
    baptiste Prando - crwdns2934203:0crwdne2934203:0
    mm pas mon fere
    Thoma Delanou -
    Excellent - Only comment - do the the green brackets come with a new hard drive or should I leave them inside the case for the next owner - Removing to donate to recycling
    sheila_jones - crwdns2934203:0crwdne2934203:0
    I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
    Elvis 1357 - crwdns2934203:0crwdne2934203:0
    Also, want to add another HD....but, there are no cables at all?
  2. Dell OptiPlex GX260 RAM Replacement, RAM: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell OptiPlex GX260 RAM Replacement, RAM: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push out on the cream colored tabs on each side of each RAM module until it pops up and out of its slot and remove the RAM.
crwdns2935229:011crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Kevin Schapansky
crwdns2935283:010/05/10crwdne2935283:0
1.478 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-48, Amido Fall 2010 crwdns2935289:0Cal Poly, Team 4-48, Amido Fall 2010crwdne2935289:0
CPSU-AMIDO-F10S4G48
crwdns2935297:027crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Rideau Cottage est construit par Stewart Taylor and Co., selon les plans de l'architecte ++Frederick Preston Rubidge++ ; le chantier commence en 1866 et se termine l'année suivante^^++[2]. Le coût de la construction s'est élevé à 5 000 ++$CA++^^++[1++]. Bien qu'il ait été prévu dans les premiers temps pour servir de résidence au ++secrétaire du gouverneur général++, le cottage est aussi utilisé par la suite comme résidence officielle pour les dignitaires en visite^^++[3^^].
Le premier agrandissement de Rideau Cottage a lieu en 1872 avec l'ajout d'un second étage et d'une ++véranda++ selon les plans de ++Thomas Seaton Scott++, architecte en chef de ++Travaux publics Canada++. En 1905, une annexe est ajoutée à l'arrière, principalement pour agrandir la cuisine. En 1933, une aile de deux étages est ajoutée au côté nord dans le but d'agrandir la salle à manger. Un porche grillagé et un garage contigu sont ajoutés par la suite. En 1954-1955 la véranda est remplacée par un ++porche++ d'inspiration classique^^++[2++^^].
antouibne - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 11,034
