Dell Inspiron 13-7352 Battery Replacement
  1. Dell Inspiron 13-7352 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7352 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7352 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 13-7352 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the battery from the rest of the device.
    In the official service manual, they also recommend the following after removing battery.:
    "Press and hold the power button for 5 seconds, to ground the system board."
    Jordan Lui - crwdns2934203:0crwdne2934203:0
For optimal performance, after completing this guide, calibrate your newly installed battery.
crwdns2935229:08crwdne2935229:0
Mikinna Martin
crwdns2935283:009/25/15crwdne2935283:0
461 crwdns2915208:0crwdne2915208:0
University of Tampa, Team 1-5, Whiteside Fall 2015 crwdns2935289:0University of Tampa, Team 1-5, Whiteside Fall 2015crwdne2935289:0
UT-WHITESIDE-F15S1G5
Last I looked up for a different model there was a video..
pc2053 - crwdns2934203:0crwdne2934203:0
Hello,
My Dell Inspiron 13-7352 won't turn on; I was using it when there was power outage and I totally drained the battery and it went off automatically, after the power came back I charged it the whole night but it still totally doesn't turn on. I tried to long-press the power button but nothing happens. I am 99% sure that the reason was using it on battery until the whole charge was gone. Please help!
jobgondwe - crwdns2934203:0crwdne2934203:0
My Dell did the same thing. I followed the above instructions to remove the battery and then put it right back in. Plugged into power and wa-la...it powered up. So simple. Thanks.
pcoladeb - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 25,148
