Dell Inspiron 13-5368 Battery Replacement
  1. Dell Inspiron 13-5368 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-5368 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-5368 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
    Note that Dell Inspiron 13s have had a rash of bad batteries that swell as they age, causing them to press hard against the trackpad. This can cause it to track poorly or make it difficult or impossible to left or right click the pad. Replacing the bad battery often fixes these kind of trackpad issues on these models where the battery is directly under the trackpad.
    Heath Connett - crwdns2934203:0crwdne2934203:0
  2. Dell Inspiron 13-5368 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 13-5368 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger / pry tool to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
    In what direction should I pull the tab. And how should I hold it
    Bam - crwdns2934203:0crwdne2934203:0
  5. Dell Inspiron 13-5368 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 13-5368 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery straight up out of the housing.
For optimal performance, after completing this guide, calibrate your newly installed battery.
crwdns2935229:014crwdne2935229:0
Matt Sugrim
crwdns2935283:009/27/17crwdne2935283:0
1 066 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S14-G6, Boczar Fall 2017 crwdns2935289:0USF Tampa, Team S14-G6, Boczar Fall 2017crwdne2935289:0
USFT-BOCZAR-F17S14G6
crwdns2935297:013crwdne2935297:0
Awesome, very user friendly instructions. Was not looking forward to taking to computer repair store to replace internal battery. Thank you so much for these instructions.
rdcath - crwdns2934203:0crwdne2934203:0
The new battery replacement does not come with a cable to attach to the motherboard. How can I use the cable from the old battery?
BilboBaggins314 - crwdns2934203:0crwdne2934203:0
I have this same question^. Can I reuse the cable from the old battery?
Gloria Kolyabin -
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 25,745
