DeLonghi ECAM Series upper brew piston replacement
  1. DeLonghi ECAM Series upper brew piston replacement, DeLonghi ECAM back panel removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the power cord!
    • Remove all attachments such as water tank, pulp drawer, brew group.
    • Turn the machine with the back facing you.
    • Remove five Torx T20 security screws.
    • A small hurdle: These screws have a pin in the middle, so the screwdriver must have a hole.
    Screwdriver must have a hole? What does that mean? Is it a standard Tx20 bit?
    Kevin - crwdns2934203:0crwdne2934203:0
    No, it is a TR20 Security Bit, which really has a hole (if you look to the star shape) . See TR10 Torx Security Screwdriver
    VauWeh -
    Bits from iFixit are equipped with it.
    VauWeh -
  2. DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift out the back.
    • The following components are immediately visible:
    • grinder
    • pump
    • flowmeter
    Sehr gute Anleitung. Die Security Schrauben der Rückwand können auch durch normale Kreuzschlitzschrauben ersetzt werden. Natürlich mit gleichen Abmessungen. Es erleichtert bei späteren Reparatur Arbeiten die Werkzeuge Auswahl , da überall Kreuzschlitzschrauben verbaut sind.
    Willi Greubel - crwdns2934203:0crwdne2934203:0
  3. DeLonghi ECAM Series upper brew piston replacement, DeLonghi ECAM Series left side panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM Series upper brew piston replacement, DeLonghi ECAM Series left side panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM Series upper brew piston replacement, DeLonghi ECAM Series left side panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the side panel back about 1.5 cm.
    • Lift off the panel.
    • The following compononents are exposed:
    • Heater
    • Expansion chamber
    • Gear drive
    • Steam valve
  4. DeLonghi ECAM Series upper brew piston replacement, Remove DeLonghi ECAM series top cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM Series upper brew piston replacement, Remove DeLonghi ECAM series top cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM Series upper brew piston replacement, Remove DeLonghi ECAM series top cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Depending on the model, the steam tap/water spout must be removed, there are slight differences here.
    • Pull out the plastic clip on the steam nozzle.
    • Pull the steam nozzle out towards you.
    Wiggle the plastic clip to pull the clip out
    Yen - crwdns2934203:0crwdne2934203:0
  5. DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull off the steam faucet toggle. Only use a plastic tool to pry to avoid damaging the bezel.
  6. DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you haven't already done so, also detach the right-hand cover on the water tank.
    • Remove the four Phillips screws securing the top cover.
    • Lift the top cover up a bit. That might be a bit sticky.
    • Don't remove the top cover completely, some models still have cables attached to the cup warmer.
    • If there is a cup warmer, then unscrew the nut SW7 with which the two green-yellow cables are connected and loosen it. The two brown cables on the other side can stay if you just put the cover on top.
    • Place the top cover on top, or remove it entirely.
  7. DeLonghi ECAM Series upper brew piston replacement, Replace the upper brewing piston: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM Series upper brew piston replacement, Replace the upper brewing piston: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM Series upper brew piston replacement, Replace the upper brewing piston: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The remaining front cover must also be removed.
    • Unscrew two screws on the left side.
    • Unscrew a screw on the right side.
    • Gently pull the front cover down. She might be a bit stuck.
  8. DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws on the control box.
    • Carefully lift the control box to one side.
    • Do not remove the box entirely, it is still connected with a ribbon cable. You can pull out the cable and put the box aside, possibly screwing it on loosely on one side.
  9. DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws on the coffee spout.
    • Lift off the coffee spout.
    • Pull off the silicone hose on the back of the coffee spout and remove the spout.
  10. DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The support of the upper piston is fixed with two screws on the left side. Depending on the model, these screws must be uncovered.
    • The first picture shows a model with an additional steam heater. Here the steam heater has to be unscrewed (one short screw on top, one further down), then it can be pulled out a few centimetres.
    • The second picture shows a model with a manual steam tap. Here the two screws on the tap must be loosened, then the steam tap can be pushed a little to the side.
    • Once the two screws are exposed, unscrew them.
  11. DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are six connections on the upper brewing piston: three hot water pressure lines, one non-pressurized waste water line, a hose line to the coffee spout and two cables to the microswitch. All must be resolved first.
    • Pull out the clip at the top left and loosen the pressure line. Pay attention to the O-ring seal. It either hangs on the line or afterwards. When reassembling, replace it with a new one if possible.
    • Pull out the clamp in the middle and loosen the pressure line. Pay attention to the O-ring seal. It either hangs on the line or afterwards. When reassembling, replace it with a new one if possible.
    • Pull out the clamp on the bottom left and loosen the pressure line. Pay attention to the O-ring seal. It either hangs on the line or afterwards. When reassembling, replace it with a new one if possible.
  12. DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two flat connectors from the microswitch connection
    Besser den ganzen Schalter mit der einen Kreuzschlitzschraube demontieren. Die Stecker sind so fest drauf das ich die Halterung, kleine weißen Lasche mit zwei Stiften zur fixierung des Schalters, herausgerissen habe
    jojo - crwdns2934203:0crwdne2934203:0
  13. DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take off the black bend protection on the middle pressure line.
  14. DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two Allen screws (4 mm).
    • Lift off the stainless steel bracket.
  15. DeLonghi ECAM Series upper brew piston replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the pressure hoses that are in the way through the openings on the left.
    • Detach any silicone hose that may be present.
    • The upper piston support plate is now free. However, it is very tight and it is tricky to get it out. Be patient and work carefully. Make sure that the ribbon cable to the control panel is not damaged.
Work the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
265.743 crwdns2915208:0crwdne2915208:0
crwdns2935297:0297crwdne2935297:0
Thanks for writing this up! The needed tools should be a security torx T20 (back cover), T15 (upper piston), Philips #2, and allen wrenches I think.
So I followed the guide but still no coffee or water from the coffee spouts. Water from the steam pipe still works. Any tips? New upper piston or something else?
Gerhard Burger - crwdns2934203:0crwdne2934203:0
Perhaps a broken or clogged solenoid valve?
VauWeh -
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 102
crwdns2942667:0crwdne2942667:0 4,036
