Use this guide to replace the lamp in a DR.J Professional HI-04 if the device is not displaying an image, or it's displaying a dim or flickering image.
The lamp creates light for the device. A faulty lamp can cause the image to be dim, flicker, or to not display at all. This can be caused by the lamp being past its lifespan or by it being broken.
Before using this guide, be sure to review the troubleshooting page. Sometimes issues with the image can be fixed by restarting the device, which wouldn't require replacing the lamp.
Flip the projector so that the bottom is facing up.
Remove the eight 10.0 mm screws with a Phillips #0 screwdriver.
Remove the two 20.0 mm screws with a Phillips #0 screwdriver.
Flip the projector so it is upright.
Remove the top case of the projector.
Remove the three pieces of tape securing cables.
Use a Phillips #0 screwdriver to remove the four 15.0 mm screws from the motherboard.
Squeeze the tab against the connector, and pull the connector straight out from the socket.
Lift the motherboard from the device.
Use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector.
Pull the cable from the connector.
Use a Phillips #0 screwdriver to remove the three 15.0 mm screws from the black cover.
Remove the single piece of black tape.
Use a Phillips #0 screwdriver to remove five 10.0 mm screws.
Remove the glass object with the orange ribbon cable connector.
Use a Phillips #0 to remove four 10.0 mm screws from the lamp.
Gently slide the lamp out from the projector case.
Hi Do you know what type of lamp can ne used for replacement please
Where can I purchase this lamp to replace in the unit or what is the model number of the lamp so I can search it out?
MTDM3025-03 is lamp part number
