Core Assembly Removal
  1. Core Assembly Removal, Unfasten the screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the four 3.9 mm-long Torx T3 screws.
    • Depending on the condition of your driver, a Torx T4 bit may fit better.
    • Don't try to detach the back cover yet. It is still connected to the watch assembly.
    The screws at least on my unit seem to be Torx T4. A T3 will work, but be careful not to strip the screws.
    Jappu - crwdns2934203:0crwdne2934203:0
    Yes! They are T4 on my watch too.
    Jim Bondly - crwdns2934203:0crwdne2934203:0
  2. Core Assembly Removal, Open the watch: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Core Assembly Removal, Open the watch: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful not to strain the sensor flex cable during this procedure.
    • Carefully lift the back cover by the watch crown edge and swing it open to an upward position.
  3. Core Assembly Removal, Disconnect the sensor cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Core Assembly Removal, Disconnect the sensor cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable.
  4. Core Assembly Removal, Remove the back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover.
  5. Core Assembly Removal, Core Assembly Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 3.7 mm-long Phillips #00 screws.
  6. Core Assembly Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Core Assembly Removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Core Assembly Removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger into the notch at the upper end of the white plastic frame.
    • Use your spudger as a lever and pry up the core assembly.
    • Don't try to remove the core assembly all the way yet—it is still connected to the watch body.
  7. Core Assembly Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Core Assembly Removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the loose edge of the core assembly up and swing it to a 100-degree angle.
    • Be careful not to strain the display and sensor flex cables during this procedure.
  8. Core Assembly Removal: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Core Assembly Removal: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the core assembly.
  9. Core Assembly Removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Core Assembly Removal: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the display flex cable from the core assembly.
  10. Core Assembly Removal: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the core assembly.
    Voor je de plastic klemmen los begint te wrikken in stap 11 moet je het vijsje dat het moederbord op de witte plastic body vasthoud losmaken en verwxijderen! (PH0 schroevendraaier)
    Bert Van den Berghe - crwdns2934203:0crwdne2934203:0
    what version on this photo, 2018 or 2020 ?
    Iwan Sunarya - crwdns2934203:0crwdne2934203:0
Repair didn’t go as planned? Check out our Answers community for help.
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
235,943 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,145crwdne2935297:0
Hello... in the event that you have submerged the smartwatch in salt water and it does not work, is there a solution?
luciano.alonso84@gmail.com - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,389
