Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement
  1. crwdns2944590:01crwdnd2944590:04crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
    Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the engine is off and cool to the touch before you proceed.
  2. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
  3. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the gas shutoff switch next to the motor to the left into the off position.
  4. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  5. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement, Remove the belt shield: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement, Remove the belt shield: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 1/2 inch socket to remove the first two bolts from the belt shield.
    • Use a 1/2 inch socket to remove the third bolt from the belt shield.
  6. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the belt shield.
  7. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a marker to mark the height of the idler pulley on the bracket.
  8. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 9/16 inch socket to loosen the nut securing the idler pulley until the pulley can freely move up and down the bracket.
    • You may need to use a 3/8 inch wrench in combination with the socket wrench to hold the bolt in place.
  9. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Raise the idler pulley to relieve the tension from the V-belt.
  10. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the V-belt.
  11. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement, Reassembly tip: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check that the idler pulley is properly tensioning the belt:
    • Use your fingers to roll the belt. If you cannot twist the belt more than a quarter turn, the belt is sufficiently tensioned. If the belt is too loose, set the idler pulley lower to tension the belt more.
  12. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement, Remove the lower V-belt: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 3/4 inch socket to remove the bolt securing the eccentric arm to the blade arm.
    • You may need to use a 3/4 inch wrench in combination with the socket wrench to hold the nut in place.
  13. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic washer from in between the eccentric arm and the blade arm.
  14. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the partially threaded bolt and plastic washer.
    • During reassembly, apply threadlocker on the bolt threads.
  15. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement, Remove the lower V-belt: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Move the cutter blade handle back to disengage the blade drive and relieve tension on the V-belt.
  16. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the eccentric arm to open a space to remove the V-belt.
  17. Classen Sod Cutter HSC18AHD 2018 Lower V-Belt Replacement, Reassembly tip: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When installing the new V-belt, ensure it is placed to the left of the bolt as pictured.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
88 046 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 1,509
