Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement
  1. crwdns2944590:01crwdnd2944590:04crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
    Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the engine is off and cool to the touch before you proceed.
  2. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
  3. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the gas shutoff switch next to the motor to the left into the off position.
  4. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  5. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement, Remove the eccentric arms: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 3/4 inch socket to remove the two bolts on the eccentric arm.
    • You may need to use a 3/4 inch wrench in combination with the socket wrench to hold the nuts in place.
    • During reassembly, apply threadlocker to the bolt securing the eccentric arm to the blade arm.
  6. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic washer from between the eccentric arm and the blade arm.
  7. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the eccentric arm away from the blade arm.
  8. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the steel washer from the eccentric shaft.
  9. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic washer from the eccentric shaft.
  10. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eccentric arm and plastic washer from the eccentric shaft.
    • Repeat steps 5–10 for the other eccentric arm.
    • During reassembly, use a grease gun to add grease to the bearings through the two Zerk fittings on each eccentric arm.
crwdns2935229:05crwdne2935229:0
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
87,927 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 2,127
