Classen Sod Cutter HSC18AHD 2018 Blade Replacement
  1. crwdns2944590:01crwdnd2944590:04crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
    Classen Sod Cutter HSC18AHD 2018 Blade Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Blade Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the engine is off and cool to the touch before you proceed.
  2. Classen Sod Cutter HSC18AHD 2018 Blade Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
  3. Classen Sod Cutter HSC18AHD 2018 Blade Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Blade Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the gas shutoff switch next to the motor to the left into the off position.
  4. Classen Sod Cutter HSC18AHD 2018 Blade Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Blade Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  5. Classen Sod Cutter HSC18AHD 2018 Blade Replacement, Unbolt the cutter blade: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the left side of the machine.
    • You may need to use a 1/2 inch wrench in combination with the socket wrench to hold the nuts in place.
  6. Classen Sod Cutter HSC18AHD 2018 Blade Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the right side of the machine.
  7. Classen Sod Cutter HSC18AHD 2018 Blade Replacement, Remove the cutter blade: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Blade Replacement, Remove the cutter blade: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Blade Replacement, Remove the cutter blade: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the cutter blade out from under the machine to remove it.
    • Do not handle the blade from the cutting edge.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
85,779 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2942667:0crwdne2942667:0 485
