Casio G-Shock GA110-1B Battery Replacement
crwdns2936621:0crwdne2936621:0
  1. Casio G-Shock GA110-1B Battery Replacement, A Guide on Battery Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio G-Shock GA110-1B Battery Replacement, A Guide on Battery Replacement: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio G-Shock GA110-1B Battery Replacement, A Guide on Battery Replacement: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four screws from the back of the watch using the Phillips #0 Screwdriver
  2. Casio G-Shock GA110-1B Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio G-Shock GA110-1B Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio G-Shock GA110-1B Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to remove the metal cover.
    • Make sure not to lose the rubber circle underneath the metal cover because it's part of the watch.
  3. Casio G-Shock GA110-1B Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the white cover carefully.
    • Using the pair of tweezers, unhook where the battery is held onto.
    • You are going to need to pull the hook will a bit of force. As seen in the video.
    • Be careful!! Do not pull it too hard with the tweezers. You don't want to damage the hook where the battery is placed.
  4. Casio G-Shock GA110-1B Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio G-Shock GA110-1B Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio G-Shock GA110-1B Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers or your fingers to remove the battery from its place.
    • Remove the new battery from its packaging.
  5. Casio G-Shock GA110-1B Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio G-Shock GA110-1B Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the new battery where it belongs with your fingers. Hook it back onto the device to secure it in place.
    • Reattach the white cover onto the device.
  6. Casio G-Shock GA110-1B Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio G-Shock GA110-1B Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio G-Shock GA110-1B Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't forget that the rubber goes 1st inside the watch before placing the metal cover.
    • Make sure that the metal cover is aligned with the watch and not upside down.
    • Put back the metal cover and screw in back the four screws using the Phillips #0 screwdriver.
    • After screwing in the four screws, flip the watch over. Push the button on the bottom left and the watch should turn on!
For optimal performance, after completing this guide, calibrate your newly installed battery.
Hector Mejia
crwdns2935283:010/05/21crwdne2935283:0
388 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 11-3, Grodsky Fall 2021 crwdns2935289:0CSU Los Angeles, Team 11-3, Grodsky Fall 2021crwdne2935289:0
CSULA-GRODSKY-F21S11G3
syncing the hands with the digital clock, should you just turn the hands?
Not A Blink - crwdns2934203:0crwdne2934203:0
found a guide online on how to set g-shock hands, just hold down reverse and forward button at the same time for a few seconds, and too long to explain, search it up or experiment with it, it's quite easy
Not A Blink -
crwdns2936753:07crwdne2936753:0 133
crwdns2936753:030crwdne2936753:0 421
crwdns2942667:0crwdne2942667:0 8,686
