This is a necessary procedure for replacing the back latch of the Canon EOS Rebel XS 35mm camera. This guide details how to remove the back latch and put a back latch back on, whether it's the same back latch or a new one. The back latch covers and protects the film, among other things.
Remove 6 screws from the base of the camera using a PH #000 screwdriver.
Remove one 7 mm screw
Remove five 4 mm screws
With your fingers, push on the bottom cover towards the back of the camera until it clicks and separates.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
With tweezers or your fingers, remove the 5 gears and place them somewhere else for the time being.
Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
Try to be gentle in removing the top cover. The transparent wheel underneath the mode dial knob can pop loose when the plastic axle's cap is already worn out.
Once the front, top, and bottom covers have all been removed, it's time to remove the back latch! Using a paperclip or something similar (anything that's very skinny), push on the end of the skinny, silver, metal rod that vertically travels through the camera. Do this until enough of the rod pops out on the other side for the next step.
With a pair of tweezers or just your fingers, pull the rod completely out of the camera. The back latch should then completely detach from the camera.
This would be fantastic if only you'd noted a place to obtain a replacement latch from.
