Canon EOS Rebel XS 35mm Back Latch Replacement
  1. Canon EOS Rebel XS 35mm Back Latch Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 6 screws from the base of the camera using a PH #000 screwdriver.
    • Remove one 7 mm screw
    • Remove five 4 mm screws
  2. Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With your fingers, push on the bottom cover towards the back of the camera until it clicks and separates.
  3. Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With tweezers or your fingers, remove the 5 gears and place them somewhere else for the time being.
    • They fall out easily while you're working, so this will help you stay organized.
  4. Canon EOS Rebel XS 35mm Back Latch Replacement, Top Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS Rebel XS 35mm Back Latch Replacement, Top Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  5. Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  6. Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off the front cover.
  7. Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
    Try to be gentle in removing the top cover. The transparent wheel underneath the mode dial knob can pop loose when the plastic axle's cap is already worn out.
    Jerome Martinez - crwdns2934203:0crwdne2934203:0
  8. Canon EOS Rebel XS 35mm Back Latch Replacement, Back Latch: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the front, top, and bottom covers have all been removed, it's time to remove the back latch! Using a paperclip or something similar (anything that's very skinny), push on the end of the skinny, silver, metal rod that vertically travels through the camera. Do this until enough of the rod pops out on the other side for the next step.
  9. Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a pair of tweezers or just your fingers, pull the rod completely out of the camera. The back latch should then completely detach from the camera.
christiansvezia
crwdns2935283:010/24/18crwdne2935283:0
1.136 crwdns2915208:0crwdne2915208:0
This would be fantastic if only you'd noted a place to obtain a replacement latch from.
David Sanborn - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 889
