Use this guide to replace the top cover on your Canon EOS Rebel T3i.
NOTE: On some variations of the Canon EOS Rebel T3i, the cables that connect the top cover to the DC PCB board are soldered on versus connected to it with a connector. If you are just removing the top cover to make other repairs, you can just keep those cables attached and carefully remove the top cover to get it out of the way. If you are replacing the top cover, you'd have to solder the cables (if they are soldered on).
Locate the battery compartment on the bottom of the camera.
Hook your finger onto the compartment door latch.
Open the battery compartment door.
Remove the battery from the compartment.
Remove the two 3 mm JIS #000 screws.
Remove the three 3 mm JIS #000 screws.
Remove the single 6 mm JIS #000 screw.
Peel back the grip tape with your fingernail.
Remove the four 5 mm JIS #000 screws.
The 6mm screw would sit in the bottom right hole, if it has this one longer screw.
Slide off the right side of the camera.
Lift off the USB cover.
Make sure the viewfinder eyepiece is removed, otherwise it will hold the top left corner of the back part in place.
After separating the back, gently lift off one side of the light blue wire with the spudger until the connector is totally removed.
With the spudger, remove the orange ribbon cable leading to the circuit board from the back of the camera.
Remove the two 6 mm JIS #000 screws.
Remove the single 6 mm and two 3 mm JIS #000 screws.
oh man, stripped the long screwtop on the left side. Any ideas how to remove it? thanks for the guide!
Use the spudger to lift the plastic under the tripod mount.
Remove the single 4 mm JIS #000 screw located near the strap mount.
On the opposite end of the camera, unscrew the screw next to the power switch using the same tool.
Remove the two 5 mm JIS #000 screws.
Disconnect this flat cable with a spudger
Disconnect this tiny plug. Make sure to only pull on the white plastic. You can use a dull single-sided razor blade to pry the white plastic connector from its base.
Remove the single 11 mm JIS #000 screw securing the dioptric adjustment knob.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the tweezers to disengage the yellow and red wires from the camera body.
Lift the top casing up and away from the camera.
Make sure the black plastic cable goes into the white plastic connector, as shown on the picture. This is a fiber optic cable that the camera flash needs in order to function. The cable can simply be pushed into the connector.
Here is a view of the black plastic bit. It is on the underside of the top cover.
I am speculating but I believe this is a fiber optic cable that has to do with the flash control. Make sure it is seated all the way down into the white plastic tube (not the metal clip in front of it). Also if you are repairing a damaged top there could be a piece of the old cable down in the hole as was the case for me and you will have to remove it before putting the new top on. I have pictures but don't see any way I can attach them here.
crwdns2935229:012crwdne2935229:0
crwdns2947412:07crwdne2947412:0
Thanks for this guide, it was helpful. I edited it to add some details, I hope they help the next person.
My camera is also this model, but I found that there were some differences, and I'm wondering it I got a refurbished device for the price of a new one... For instance the top cable were soldered to the front of the camera, no plug in sight. I found more than 1 screw that had a different thread to the others.
All in all I managed to fix my issue which was with the viewfinder. The 550D guide for the viewfinder will work for this camera (I just used it and the viewfinder parts are exactly the same) Canon EOS Rebel T2i Eyepiece Replacement
There are some models of Canon Rebel cameras where the two cables which connect the top cover to the DC PCB board are soldered on instead of connected with connectors. This difference must also be found between different variations of the Canon Rebel T3i too.
As far as the screw threads go, most of the screws will be M1.7, but there will also be some places where they use M2.0 screws too. There may also be the occasional place where another thread type is used too, such as the hot shoe. It's definitely recommended to keep track of where exactly every single screw you take off goes to avoid putting any back in the wrong spot.
Zephosk -
Good guide, only comment I have is there is a cover over the viewfinder that you need to remove initially, you just pull up on it and it pops off. If you look closely at the viewfinder on the camera in the pictures you will probably see that it does not have a cover around the viewfinder that your camera does. This needs to be removed before removing the back of the camera.
For me some bolt sizes were also different, i just labeled every bolt location with a piece of tape with a number written on it, and kept track of the bolts.
This briliant. I don't dare to unscrew my camera yet but if I do this will certainly help. I did do the back cover already but the top cover is serious business. Thanks a lot for the many photo's provided.
Excelent step-by-step! I managed to fix my camera's flash mechanism without buying any part.
By the way, that small plastic that looks a cable but it's not a cable is an optic fiber, that carries a small amount of the flash light to a sensor on the board.
A lens in the eyepiece of my 600D was popped out. I used this guide and this one: Canon EOS Rebel T2i Eyepiece Replacement to fix it. Thanks!
Top cover의 작은 lcd 교체하는법 알고 싶습니다.
