Many Patagonia backpacks feature a removeable sternum strap, also known as a chest strap, designed to alleviate shoulder pressure and distribute weight more evenly across the chest.
This guide demonstrates how to reattach one specific style of Patagonia sternum strap - the c-clamp - named for its C-shaped cross-section. This style was used on some packs produced between 2009 and 2018.
Replacement parts are currently unavailable. To get a new sternum strap, take your pack in to a local Patagonia retail store for repair evaluation or send it in to Patagonia through their mail-in repair service.
Locate the sternum strap that has come off the pack.
Replacements for this style of sternum strap are not currently available, so if part or all of the sternum strap is missing, reach out to Patagonia for alternative options.
The 'c-clamp' piece of the sternum strap fits over a plastic tube or ‘rail’ that is inside the backpack strap. At the bottom of this rail there is a fabric flap.
Pull back the fabric flap to expose where the rail ends. This is where the c-clamp was designed to be slid on and off.
At the exposed area at the base of the rail, slide the c-clamp back onto the rail.
Pull tightly on the fabric flap to expose the area.
Maneuver as if parallel parking a car. Start at an angle, slide partially onto the rail, and then straighten out.
Repeat the steps above on the other backpack strap.
Slide the sternum strap to your desired position.
Hit the trails with your newly attached sternum strap!
This is helpful, except where do I find the replacement part! I contacted Patagonia and they no longer make it; they said to try a local sporting goods store or to send to Patagonia and they'll sew on a new daisy-chain version. My local REI does not have these parts either. Bummer!
You can find one on Etsy: https://www.etsy.com/listing/1320149223/...
