Braven BRV-1M Button Register Replacement
Erik Oliva
crwdns2944109:0crwdnd2944109:0Erik Olivacrwdnd2944109:0crwdnd2944109:0crwdnd2944109:0crwdne2944109:0
crwdns2944111:0May 28, 2018crwdne2944111:0
20 - 30 crwdns2931279:0crwdne2931279:0
crwdns2937803:0crwdne2937803:0
crwdns2944105:0crwdne2944105:0
  1. Braven BRV-1M Button Register Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Button Register Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Button Register Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Button Register Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
    And where do I purchase a new outer case? My on off button rubber perished.
    Louise Maree - crwdns2934203:0crwdne2934203:0
  5. Braven BRV-1M Button Register Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
  6. Braven BRV-1M Button Register Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Then, proceed to unscrew the 5 Phillips #00 bit type, 9mm long screws located on the face of the charging dock.
  7. Braven BRV-1M Button Register Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two 4-pin auxiliary button register cables connected on both sides of the motherboard.
  8. Braven BRV-1M Button Register Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once disconnected, carefully remove the motherboard by pulling upwards.
  9. Braven BRV-1M Button Register Replacement, Button Register: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the button registers, unscrew the two Phillips #00 bit type, 6 mm screws found on both sides of the control registers.
  10. Braven BRV-1M Button Register Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the control registers from the housing of the device.
Erik Oliva
crwdns2935283:002/14/18crwdne2935283:0
607 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G1, Eyestone Spring 2018 crwdns2935289:0USF Tampa, Team S2-G1, Eyestone Spring 2018crwdne2935289:0
USFT-EYESTONE-S18S2G1
Great guide! Do you know the spec/name of the button registers so that I can purchase a new one to replace a dysfunctional one?
Mason McElvain - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 372
