Boss CE-300 Super Chorus Switches Replacement
  1. Boss CE-300 Super Chorus Switches Replacement, Top Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the 3 14.8 mm screws located on the left side of the CE-300.
    • Repeat the previous bullet on the right side.
  2. Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 10 mm bolts using a Phillips #2 screwdriver.
  3. Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the back of the CE-300, remove the two 7.5 mm screws with a Phillips #2 screwdriver.
  4. Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the left side, remove the one 10 mm screws with a Phillips #2 screwdriver.
  5. Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the top panel away from the front.
    • Lift the panel up and off.
  6. Boss CE-300 Super Chorus Switches Replacement, Bottom Panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws with a Phillips #2 screwdriver:​
    • Two 7.5 mm
    • Two 10 mm
  7. Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bottom panel up and off.
  8. Boss CE-300 Super Chorus Switches Replacement, Face plate: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 5.7 mm screw on the left side of the face plate.
    • Repeat the previous step on the right side of the face plate.
  9. Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all dial covers.
  10. Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • From the inside of the unit, pinch the 3 clips holding the faceplate in
    • Do not use any metal tool to pinch the clips. If metal damages the board, it may be unrepairable.
    • Push the clips in and the face plate will slide off.
  11. Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a 11 mm wrench or socket, remove the five nuts around the dials.
  12. Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a 14 mm wrench or socket, remove the three nuts around the jacks.
  13. Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three switch covers.
  14. Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the single 7.8 mm screw on the left side of the bracket.
    • Repeat the previous bullet on the right side of the bracket.
  15. Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Switches Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two audio jacks that are to the side.
    • Do not pull the face bracket fully off and away. Some cables will remain attached to the face bracket and to the board.
    • Carefully remove the face bracket by sliding it forward until it clears all dials, then lift up.
  16. Boss CE-300 Super Chorus Switches Replacement, Switches: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Switches Replacement, Switches: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • From the "top" of the board, desolder the marked joints.
    • For some switches, the board is labeled to help identify the correct switch. The switch shown in the second picture is the "Direct Mute" switch.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Mohamed Eldahan
crwdns2935283:009/25/24crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 1-2, Sneed Fall 2024 crwdns2935289:0University of Memphis, Team 1-2, Sneed Fall 2024crwdne2935289:0
UM-SNEED-F24S1G2
crwdns2942667:0crwdne2942667:0 48
