Boss CE-300 Super Chorus Front Panel Audio Jack Replacement
  1. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement, Top Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the 3 14.8 mm screws located on the left side of the CE-300.
    • Repeat the previous bullet on the right side.
  2. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 10 mm bolts using a Phillips #2 screwdriver.
  3. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the back of the CE-300, remove the two 7.5 mm screws with a Phillips #2 screwdriver.
  4. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the left side, remove the one 10 mm screws with a Phillips #2 screwdriver.
  5. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the top panel away from the front.
    • Lift the panel up and off.
  6. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement, Bottom Panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws with a Phillips #2 screwdriver:​
    • Two 7.5 mm
    • Two 10 mm
  7. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bottom panel up and off.
  8. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement, Face plate: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 5.7 mm screw on the left side of the face plate.
    • Repeat the previous step on the right side of the face plate.
  9. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all dial covers.
  10. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • From the inside of the unit, pinch the 3 clips holding the faceplate in
    • Do not use any metal tool to pinch the clips. If metal damages the board, it may be unrepairable.
    • Push the clips in and the face plate will slide off.
  11. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a 11 mm wrench or socket, remove the five nuts around the dials.
  12. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a 14 mm wrench or socket, remove the three nuts around the jacks.
  13. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three switch covers.
  14. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the single 7.8 mm screw on the left side of the bracket.
    • Repeat the previous bullet on the right side of the bracket.
  15. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Front Panel Audio Jack Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two audio jacks that are to the side.
    • Do not pull the face bracket fully off and away. Some cables will remain attached to the face bracket and to the board.
    • Carefully remove the face bracket by sliding it forward until it clears all dials, then lift up.
  16. Boss CE-300 Super Chorus Front Panel Audio Jack Replacement, Front Panel Audio Jack: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Boss CE-300 Super Chorus Front Panel Audio Jack Replacement, Front Panel Audio Jack: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Boss CE-300 Super Chorus Front Panel Audio Jack Replacement, Front Panel Audio Jack: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • From the "top" of the board, desolderthe marked joints.
    • The board has labels for some of the joints. Double check that you are de-soldering the correct joints.
    • For the two audio jacks on the side, you can replace them without fully removing the face plate.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Haley Lansdon
crwdns2935283:009/25/24crwdne2935283:0
619 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 1-2, Sneed Fall 2024 crwdns2935289:0University of Memphis, Team 1-2, Sneed Fall 2024crwdne2935289:0
UM-SNEED-F24S1G2
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 48
