This guide provides instructions for replacing the front panel audio jacks on the Boss CE-300 Super Chorus, a popular analog effects processor known for its high-quality chorus sound. The audio jacks are crucial for connecting input and output signals, and over time, they can wear out, leading to issues like weak signals or unstable connections. Replacing the jacks will help restore the device’s performance and usability.
The procedure involves partially disassembling the front panel and carefully removing the damaged jacks by de-soldering them from the circuit board. Required tools include a Phillips #2 screwdriver, 11mm and 14mm wrenches, a soldering iron, and a desoldering pump or braid for precise solder removal.
Take care to avoid damaging the circuit board during de-soldering, and ensure the unit is unplugged and powered off before starting. Follow the steps carefully to complete the replacement safely and effectively.
Use a Phillips #2 screwdriver to remove the 3 14.8 mm screws located on the left side of the CE-300.
Repeat the previous bullet on the right side.
Remove the two 10 mm bolts using a Phillips #2 screwdriver.
On the back of the CE-300, remove the two 7.5 mm screws with a Phillips #2 screwdriver.
On the left side, remove the one 10 mm screws with a Phillips #2 screwdriver.
Slide the top panel away from the front.
Lift the panel up and off.
Remove the following screws with a Phillips #2 screwdriver:
Two 7.5 mm
Two 10 mm
Remove the single 5.7 mm screw on the left side of the face plate.
Repeat the previous step on the right side of the face plate.
From the inside of the unit, pinch the 3 clips holding the faceplate in
Push the clips in and the face plate will slide off.
With a 11 mm wrench or socket, remove the five nuts around the dials.
With a 14 mm wrench or socket, remove the three nuts around the jacks.
Use a Phillips #2 screwdriver to remove the single 7.8 mm screw on the left side of the bracket.
Repeat the previous bullet on the right side of the bracket.
Remove the two audio jacks that are to the side.
Carefully remove the face bracket by sliding it forward until it clears all dials, then lift up.
From the "top" of the board, desolderthe marked joints.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
