Boss CE-300 Super Chorus Dial Replacement
  1. Boss CE-300 Super Chorus Dial Replacement, Top Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the 3 14.8 mm screws located on the left side of the CE-300.
    • Repeat the previous bullet on the right side.
  2. Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 10 mm bolts using a Phillips #2 screwdriver.
  3. Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the back of the CE-300, remove the two 7.5 mm screws with a Phillips #2 screwdriver.
  4. Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the left side, remove the one 10 mm screws with a Phillips #2 screwdriver.
  5. Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the top panel away from the front.
    • Lift the panel up and off.
  6. Boss CE-300 Super Chorus Dial Replacement, Bottom Panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws with a Phillips #2 screwdriver:​
    • Two 7.5 mm
    • Two 10 mm
  7. Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bottom panel up and off.
  8. Boss CE-300 Super Chorus Dial Replacement, Face plate: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 5.7 mm screw on the left side of the face plate.
    • Repeat the previous step on the right side of the face plate.
  9. Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all dial covers.
  10. Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • From the inside of the unit, pinch the 3 clips holding the faceplate in
    • Do not use any metal tool to pinch the clips. If metal damages the board, it may be unrepairable.
    • Push the clips in and the face plate will slide off.
  11. Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a 11 mm wrench or socket, remove the five nuts around the dials.
  12. Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a 14 mm wrench or socket, remove the three nuts around the jacks.
  13. Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three switch covers.
  14. Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the single 7.8 mm screw on the left side of the bracket.
    • Repeat the previous bullet on the right side of the bracket.
  15. Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Dial Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two audio jacks that are to the side.
    • Do not pull the face bracket fully off and away. Some cables will remain attached to the face bracket and to the board.
    • Carefully remove the face bracket by sliding it forward until it clears all dials, then lift up.
  16. Boss CE-300 Super Chorus Dial Replacement, Dial: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boss CE-300 Super Chorus Dial Replacement, Dial: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the marked joints from the "top" of the board.
    • Some dials are labeled on the board to help identify what solder joints lead to what dial. Double check that you de-solder the correct joints.
    • The second picture demonstrates desoldering of the "chorus level" dial.
    • Remove the dials.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Haley Lansdon
crwdns2935283:009/25/24crwdne2935283:0
628 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 1-2, Sneed Fall 2024 crwdns2935289:0University of Memphis, Team 1-2, Sneed Fall 2024crwdne2935289:0
UM-SNEED-F24S1G2
crwdns2942667:0crwdne2942667:0 94
