Bose Solo 5 Sound Bar Control Panel Replacement
Emma
crwdns2944107:0crwdnd2944107:0Emmacrwdnd2944107:0crwdnd2944107:0crwdnd2944107:07crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Nhl 16, 2024crwdne2944111:0
20 - 30 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
The following guide explains in detailed steps including pictures on how to replace the control panel of the Bose 5 Sound Bar. The control panel is responsible for controlling the power and the output of the Bose 5 Sound Bar. It may be necessary to replace the control panel if the sound bar does not produce sound when it is plugged into the TV. Upon completion of the control panel replacement, the Bose 5 Sound Bar should work as expected. Otherwise, it would indicate that your system has a different problem.
Before using this guide, be sure to test different audio cables that connect the sound bar to the TV to confirm that the faulty part is coming from the sound bar. Before beginning, make sure to disconnect the sound bar from the TV.
  1. Bose Solo 5 Sound Bar Control Panel Replacement, Control Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay Bose Solo 5 with speakers facing away from you and bottom side facing upward.
  2. Bose Solo 5 Sound Bar Control Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Solo 5 Sound Bar Control Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 18.25mm screws with the Phillips #2 screw driver.
  3. Bose Solo 5 Sound Bar Control Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the gold plates snap connector from the circuit board by pulling it apart.
  4. Bose Solo 5 Sound Bar Control Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, lift the circuit board up and remove from housing.
  5. Bose Solo 5 Sound Bar Control Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Solo 5 Sound Bar Control Panel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the cords running to the white connecter by pulling up on the tab until it is disconnected completely.
    Anyone every found this control board to purchase?
    jdcaldecott - crwdns2934203:0crwdne2934203:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Emma
crwdns2935283:010/05/18crwdne2935283:0
506 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team S15-G7, Blackburne Fall 2018 crwdns2935289:0Sam Houston State, Team S15-G7, Blackburne Fall 2018crwdne2935289:0
SHSU-BLACKBURNE-F18S15G7
Does anyone know where to buy a replacement logic board? I’ve been searching for a while now, no dice.
Tyler Barney - crwdns2934203:0crwdne2934203:0
hallo und wo bekomme ich das Ersatzteil die Platiene 73252 Delta 3
APP TISCHNER - crwdns2934203:0crwdne2934203:0
Has anyone had any luck finding the same board. Im looking.
ka.wells - crwdns2934203:0crwdne2934203:0
I know how to open it. What I don't know is where to buy one.
szanti - crwdns2934203:0crwdne2934203:0
If anyone was able to find the board, it wuold be great to know where did you find it. Looking for this board during months...
Juan Ramirez - crwdns2934203:0crwdne2934203:0
Aliexpress have the Bose Solo 5 PCB $47
Jason Spring - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 133
crwdns2942667:0crwdne2942667:0 14,487
