Black and Decker Pivot Plus PD600 Battery Replacement
  1. Black and Decker Pivot Plus PD600 Battery Replacement, Drill: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Black and Decker Pivot Plus PD600 Battery Replacement, Drill: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Black and Decker Pivot Plus PD600 Battery Replacement, Drill: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the nine 15mm Philips #1 screws
    • Remove the two 12.5mm Philips #1 screws
    • Remove the two 10mm Philips #1 screws
  2. Black and Decker Pivot Plus PD600 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
    Dónde llevan los bujes de la a parte que van los engranes
    Rigoberto Silva - crwdns2934203:0crwdne2934203:0
  3. Black and Decker Pivot Plus PD600 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the battery and remove it from its slot at the end of the drill opposite the motor. It should be at the butt of the drill by the handle.
    what kind of batteries can I use to replace them
    K3Ls - crwdns2934203:0crwdne2934203:0
    I don't know what type of batteries are used in this drill, but you can buy them by clicking on the link entitled Black and Decker Pivot Plus PD600 Replacement Parts on the main page, or by using the below
    http://www.ereplacementparts.com/black-a...
    Jonathon Centofranchi - crwdns2934203:0crwdne2934203:0
    You should do a related tutorial on building your own replacement battery pack in this configuration, as this is used with the 600/600G and 700 G models.
    F V - crwdns2934203:0crwdne2934203:0
    1. What if you discover broken wires at the solder joints on the circuit board? 2. Which part of the charger connector is + and -? (The pin, or the shield?) Miike Smith 8/19/2021
    maddogsmith2003 - crwdns2934203:0crwdne2934203:0
    Is there a schematic for the circuit board available?
  4. Black and Decker Pivot Plus PD600 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery by pulling out both the red and black wires. They should come out easily with a little bit of force.
    • But be careful not to disconnect the wire from the metal it is attached to. In order to avoid this, pull the wire out by holding on to the metal part instead of just the wire.
  5. Black and Decker Pivot Plus PD600 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now take the replacement battery and slide the metal parts of the wire into the metal part of the battery.
    • Make sure that the red wire connects to the curved end of the battery, and that the black wire connects to the straight end of the battery.
    It's possible to email me the battery and battery charger specifications
    Saeed.eslamikia43754@gmail. Com
    Saeed - crwdns2934203:0crwdne2934203:0
    The battery replacement pack is nearly as expensive as a new drill and seemingly unavailable (universally marked for backorder), making this impractical for two reasons. Can someone who has replaced the battery pack disassemble it so we can see what components it’s made of? It may be easier to rebuild the battery pack from individual components rather than to order a stock one.
    Also, the wires from the PCB connected to the motor are on the other side of the joint (where the drill bends), making the connections susceptible to metal fatigue. The black wire attached to the motor on my drill broke free from years of switching the joint from straight to charge and bent to use. I fixed it with scrap wire, cable ties, and a hot glue gun to ensure it never happens again.
    Kevin Fishburne - crwdns2934203:0crwdne2934203:0
    Very disappointed in this product!!!
    Donna Trezza - crwdns2934203:0crwdne2934203:0
crwdns2935229:09crwdne2935229:0
crwdns2935283:004/19/13crwdne2935283:0
307 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-15, Maness Spring 2013 crwdns2935289:0Cal Poly, Team 4-15, Maness Spring 2013crwdne2935289:0
CPSU-MANESS-S13S4G15
crwdns2947412:011crwdne2947412:0
this drill adapter, why "6V" and the adapter body is marked 9VAC output? which is true output?
Can someone test the output and tell me the voltage? VDC? VAC? thankyou.
u411323 - crwdns2934203:0crwdne2934203:0
Unfortunately I do not own the drill anymore so I can't test its output. I do know that the battery used is 6V, so I would assume that is the output. Hopes this helps!
Where can I buy the replacement battery pack for less than replacing the tool?
shgarceau - crwdns2934203:0crwdne2934203:0
Well, I just checked B & D's web site and can buy a battery pack for $17.95 PLUS $10.99 shipping (cheapest offered).
I think buying a new one is a better idea.
Fast forward to 2021 you cant even buy the battery any longer. Another reason I do not truck with B and D anymore. This one will go where it belongs IN THE TRASH ! Even when you could buy it,it was way overpriced.
RAY W - crwdns2934203:0crwdne2934203:0
Where do I order the replacement battery
Kathleen Wyatt - crwdns2934203:0crwdne2934203:0
On mine, you only have to loosen the butt end screw a little and pop the butt cap off, then release the red wire, gently pull out the pack, remove the black ground and reverse with the new battery. Wasted 15 minutes finding the tiny philips for the on screw by the drill/screw switch.
DR COOL - crwdns2934203:0crwdne2934203:0
The replacement battery is no longer available through Black & Decker. Does anyone know an alternative or work around?
Bruce Rosen - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 100
crwdns2942667:0crwdne2942667:0 29,565
