Behringer Eurolive B212D Control PCB Replacement
crwdns2942287:0crwdne2942287:0The control PCB is attached to the inside of the back panel, and provides access to adjustment knobs and inputs and outputs for the B212D speaker.
Remove the 8 Phillips screws from the back of the speaker.
Carefully remove the back panel, lifting out the metal electronics-box with it.
There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
Remove the portion of the metal housing that you freed with the 7 screws in the previous step.
Inside the metal electronics box housing is a white clip attached to a small PCB; remove this.
Snake the clip head through the hole in the metal electronics box casing.
Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
Rotate the back panel so you can view the interior; note the three wires attached.
Remove the wires to you can fully remove the back panel.
Remove the 4 indicated 9/32" long screws with the #1 phillips head screwdriver
Remove all three of the knobs by pulling them straight up.
Remove the 4 indicated 9/32" long screws using a #1 phillips head screwdriver.
Remove the 2 indicated 3/16" long machine screws with a #1 phillips head screwdriver.
The control PCB is free now, ready to be removed from the speaker's back panel.
crwdns2947412:05crwdne2947412:0
In Step 3 there are 2 more screws, along the side of the 'electronics box’.
The washer and nut securing the 1/4” socket also need to be removed.
Where do I find a replacement control PCB for my B212A??
Hi,i like to conect the board to another amp pcb but i dont now wich cable is for what ,do you now where is the power and the inputs?i already look for schematics but i didnt find anything about..thanx
Hi
My Behringer Eurolive B215D speaker has got a serious hissing sound when I plug just the power with no audio player connected. Anyone with any idea what can course this? Thanks.
Eurolive B212d back plate requirement
Ashok Ahlawat - crwdns2934203:0crwdne2934203:0
