Beats Solo 3 Battery Replacement
  1. Beats Solo 3 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Solo 3 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the outside pane on the right side of the headphone with an opening tool.
  2. Beats Solo 3 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You should see your battery here. It will be square with yellow packaging.
    • Be sure not to pull on the wires that are connected to the outside panel. This may cause damage to your headphones.
  3. Beats Solo 3 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Solo 3 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the battery's small bundled connector, and pull gently to remove.
    • Carefully remove the top attachment from the headphones with tweezers or your fingers.
  4. Beats Solo 3 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Solo 3 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool or a nylon spudger to carefully remove the battery. Make sure you pry upward.
    • Do not bend or puncture the lithium-ion battery.
    • Once that is removed, make sure you peel off the sticker where the battery is placed if it stuck to the battery.
    • If it is, then place it back where it belongs in the headphones.
McKenzie Hosey
crwdns2935283:003/21/22crwdne2935283:0
315 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 1-2, Bedsole Spring 2022 crwdns2935289:0University of Alabama, Team 1-2, Bedsole Spring 2022crwdne2935289:0
UA-BEDSOLE-S22S1G2
crwdns2935297:011crwdne2935297:0
Google . Internet
Mari Carmen Núñez -
Thank you! This worked great!
NYCGinkgo - crwdns2934203:0crwdne2934203:0
Hello I have an issue where the battery is soldered on and only has two wires can anyone advise. My headphones are beats solo3
agustin rodiles - crwdns2934203:0crwdne2934203:0
same issue too
ethan b -
beats solo battery plug panel is broken
ethan b - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 100
crwdns2936753:030crwdne2936753:0 415
crwdns2942667:0crwdne2942667:0 19,440
