crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Beats Solo3 Troubleshooting
This is a troubleshooting page that will help you diagnose the problems relating to your Beats Solo 3s.
Beats Solo3 will not connect to an external device
The device is not showing any signs of being able to connect to an external device such as a mobile phone or laptop.
Beats Solo3 is not paired through Bluetooth
The issue may not be with the Beat Solo3 and may be with the device. Your device may not be paired with the Bluetooth headset. Ensure Bluetooth is active on your device. Go to your device's Bluetooth settings, and make sure you have paired your Beats Solo3 to your device.
Faulty battery
Connect the headphones to the charger, and charge the headphones to full capacity. Apple states that it should take approximately 2 hours to fully charge. Once charged, power on and try to reconnect again. If the problem persists and it is clear that the battery adapter is not faulty, the battery of the device may be the issue. You can find a replacement guide here.
Faulty Bluetooth connector/ adapter
If the headphones are fully charged and the issue still persists, it is likely that there is an issue with the Bluetooth connector/adapter on your audio board. You can find a replacement guide for the audio board here.
Distorted sound coming from speakers of Beats Solo3
The device is not projecting clear audio making it difficult to hear
Headphones need to be reset
Turn off the headphones and leave them off for ten seconds, and then turn them back on.
Faulty speakers
Check to see if the audio coming from the source device is not distorted by connecting to an alternate Bluetooth speaker. If the actual audio is distorted on the Solo3 headset, it is possible that there is damage to the speakers. If the issue continues, you may need to replace the speakers. You can find a replacement guide for the headset speakers here.
Faulty Bluetooth/ connection
If the headphones are fully charged, then there could be damage to the Bluetooth connector/adapter. This can result in distorted audio. You can find a replacement guide here.
The right side speaker is not working
When the device is fully charged audio-only projects from the left side speaker
The Bluetooth connection is not working
Make sure your headphones are powered on and you are at a close proximity to the device. Beat Solo3 headphones may have a Bluetooth range of ~400 feet, but to ensure a connection try to have your device close by.
Faulty speakers
If the battery is working properly and Bluetooth seems to be connecting correctly, it is likely that there has been some internal damage to the speaker.
Faulty audio board
It is possible that the internal audio board has been damaged resulting in the right side speaker no longer functioning. Consider opening the headphones to view the audio components. Take note of any loose wires or other abnormalities. If possible try reconnect any loose wiring. If all appears to be in place and no visible damage, the audio board should be replaced. Please follow the steps listed here.
Beats Solo3 will not power on
The device will not turn on and the power button will not flash to show headphones are discoverable.
Beats Solo3 is not charging
Beats Solo 3 come with a micro USB charging cable. According to Apple, the headphones should take around 2 hours to fully charge.
Faulty charger
The issue could be with the charging cable and not with the Beats Solo3. A new charging cord may need to be purchased.
Faulty battery
Try to charge your Beats Solo3 headset with a charger you know is not faulty. If the Beats Solo3 headset will still not turn on or charge, the battery may need to be replaced.
Faulty charging port
Plug charger into charging port on Beats Solo3. If they do not charge, check to make sure the charging cable is working. Check to see if there are any visible damages to the charging cable. If so, the charging port may need to be replaced.
Beats solo3 is not charging
The device is not charging when it’s plugged in.
Faulty power adapter
Make sure the adapter is plugged in and the light is on. If the light is not on while the adapter is plugged in, consider purchasing a new adapter.
Faulty battery
If the adapter is plugged in, the light of the adapter is on and the charger is not charging, try to use another charger.
If the charger is not latching into the charging port, try to use another charger. If another charger is not working, the shape of the charging port could be damaged. Consider replacing the charging port. The steps for this can be found here.
The microphone does not pick up sound
Microphone does not pick up audio.
Microphone is covered
The microphone is located on the ear cup. Make sure there is no physical interference with it. You can also clean your Beats Solo3 with a dry cleaning cloth to ensure there is no dust or oil blocking the microphone.
Faulty audio board
It is possible that the internal audio board has been damaged resulting in the microphone to no longer function. Consider opening the headphones to view the audio components. Take note of any loose wires or other abnormalities. If possible try reconnect any loose wiring.
Jakub Karl
crwdns2935283:003/21/22crwdne2935283:0
216 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 1-2, Bedsole Spring 2022 crwdns2935289:0University of Alabama, Team 1-2, Bedsole Spring 2022crwdne2935289:0
UA-BEDSOLE-S22S1G2
crwdns2935297:048crwdne2935297:0
crwdns2944067:025crwdne2944067:0
The light is flashing when trying to charge but it’s not actually charging what do I do
Serena Smith - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
i have the same thing right now and don’t know what to do…if you fixed it please tell me how it got fixed
Hala Elk - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Brand new Beats Solo 3s light doesn’t turn on at all even when I charged them. Switched chargers and still doesn’t work.
Payton H - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The left side of the headphones will not work even when they are fully charged.
Addison Stork - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 192
crwdns2959996:0crwdne2959996:0 60,567
