Basic - How to setup a photo studio to take better photos
  1. Basic - How to setup a photo studio to take better photos, Choosing a camera: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Choosing a camera: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Choosing a camera: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you buy a used DSLR/Mirrorless camera, ask for the shutter count. If the seller does not know or will not check, look for a camera with known shutter count data (or ask for an average). IF YOU BUY YOUR CAMERA USED, IT IS VERY LIKELY THE INCLUDED BATTERY IS "CONSUMED".
    • Mirrorless cameras with a high shutter count are likely fine (most have ~200-250k mech shutters) but should be discounted to match.
    • Canon: GENERAL INFO; EOSSMMG (Windows); EOS Digital Info (Windows); ShutterCheck (Mac)
    • Sony: ShutterTool
    • Smartphone: The camera you already have. For the most part, many have cameras which are good enough (or are "P&S quality"). While not as good as a Mirrorless or DSLR camera, image quality is generally good enough.
    • Mirrorless: These are similar to DSLRs but have fewer moving parts and smaller bodies. These use the same sensors as DSLR cameras, but have different lens mounts. In most cases, older SLR lenses can be used with an adapter (Sony LA-EA, Canon RF>EF, Nikon F>Z).
    • DSLR: Similar to Mirrorless cameras, but use different lenses and have larger bodies. These still get better battery life compared to mirrorless cameras. It is not uncommon for lenses to be cheaper due to the used market. NOTE: I am showing a prosumer DSLR, but it is not required.
    • Point and Shoot: Due to smartphone camera advancements, these have become less common but are still worth considering. Due to smartphones being “good enough” today, MOST P&S cameras have been discontinued. You are (generally) better off with a used high-end P&S these days.
  2. Basic - How to setup a photo studio to take better photos, *Used cameras* Did you get a "consumed" battery?: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, *Used cameras* Did you get a "consumed" battery?: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, *Used cameras* Did you get a "consumed" battery?: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • SOME SELLERS UNKNOWINGLY BIN COUNTERFIT BATTERIES. IF YOU SEE ANY RED FLAGS, IT MAY BE COUNTERFIT.
    • If you buy a used camera (Mirrorless, DSLR, P&S), any included battery is likely near EOL. Batteries are considered "consumable" with limited coverage. This is especially true with a used camera.
    • There is no catch-all method to check this. Many older cameras lack support for this, or it is restricted to prosumer and pro cameras. On cameras with poor monitoring, you will need to make a judgment call. See this 80D as an example of proper health monitoring.
    • Refer to your camera's menu system to see how to check this as each brand is different. For example, the battery I got with my Canon 80D from 6/2017 is essentially in very poor condition and "end-of-life". I still use it but I do not trust it in the field without a healthy pair of spares.
    • The seller this 80D came from "included" this battery, but likely knew it was nearing the end of it's usable life. I cannot verify this as absolute fact, but this is VERY common with used cameras.
    • Batteries without monitoring: If your battery has no/poor monitoring, look for a date stamp. If it is over 3 years old WITH limited runtime, consider it consumed.
  3. Basic - How to setup a photo studio to take better photos, Budget - Picking bulbs: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Budget - Picking bulbs: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Budget - Picking bulbs: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Try and stick to >90+ CRI 5000-5500k (>90+ CRI) bulbs as these are more beginner-friendly; 6000-6500k bulbs often require heavier correction or a custom WB setting. For >80 CRI bulbs, a custom WB can help offset the poor light quality.
    • IF YOU HAVE OVEREXPOSURE ISSUES, set the exposure comp to -0.5-1.0 as needed. If this does not help, correct it in post.
    • CFL (AVOID): Avoid using CFLs, even on clearance. They are not as bright as LEDs, take time to warm up and contain mercury (disposal is hard). They also tend to fail young due to cheap ballasts and components that do not get along with heat.
    • BR30/40: These produce a focused beam of light which can result in better photos compared to omnidirectional bulbs. These bulbs must be used in a specific direction by design.
    • A19: While these work the light can be somewhat unbalanced or scattered without redirection. You must use a minimum of 100W for good photo lighting.
    • Multi-panel workshop lighting: These produce significantly more light than floodlights, but can only be used where weight is not an issue and well spaced to avoid overexposure.
  4. Basic - How to setup a photo studio to take better photos, Budget - Lighting setup: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Budget - Lighting setup: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Budget - Lighting setup: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Items like inexpensive big box store tripods with missing parts can be "upcycled" to help reduce setup costs. It is also possible to use other items like "BER" lamps.
    • Side lighting
    • Tripod or light stands: If you can find a pair of quality tripods, these can often be used as makeshift light stands. High-end tripods are not required, but nice to have.
    • Standing lamp: Space may be an issue with lamps that have a base, but if you can make this work a broken lamp (with the cord and socket removed) can be used.
    • Edge cases
    • Over the top: This method requires specific setup conditions not always feasible without a dedicated workspace. However, this method can allow the use of one bright LED instead of 2 when it works (must use 1,500-2,000+ lumens).
    • Side clamping: This works in a pinch, but should be considered a last resort. Light placement may be restricted which can show in the final photo. Look into better options first.
  5. Basic - How to setup a photo studio to take better photos, Custom WB - Sony (Alpha, Mirrorless)/Optional: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Custom WB - Sony (Alpha, Mirrorless)/Optional: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Custom WB - Sony (Alpha, Mirrorless)/Optional: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • I cannot confirm how to set the WB on: Nikon cameras; Sony DSLRs, "NEX"; >10-year-old DSLRs; problematic cameras (Ex: E58/FFB KM Maxxum 7D/5D). YOU ARE ON YOUR OWN WITH THESE!
    • Early entry-level Sony Alpha cameras (a5X00) are primarily SW-driven. Advanced cameras (a6X00 and full-frame) are hardware-controlled. This is the only difference between body "types"; everything else is the same.
    • Sony: Sony a5X000 (SW driven) Sony Alpha (Advanced, a6X00 and up) Sony NEX (FOR NEX-5N; NOT CHECKED)
    • Switch the camera into a Manual mode (P/A/S/M; doesn't matter). You MUST be in a "manual" mode to use custom WB settings.
    • Open the menu and select the following: Camera settings>White Balance.
    • NOTE: The location of the white balance setting varies from camera to camera. Keep this in mind if you do not see the setting as shown in my demo a6000. (Ex: a6000 is Line 4, a6100 is under Line 9 and a6300 is under Line 5.
    • In addition to menu deviation, Sony also has removed the option to use a photo to set a custom WB; you must dial in the color temperature of your studio lighting.
    • Select the White Balance option, and scroll down until you see Custom Setup. Take a picture of your lighting setup and press the Enter button to save it to the camera.
  6. Basic - How to setup a photo studio to take better photos, Custom WB - Canon/Optional: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Custom WB - Canon/Optional: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Custom WB - Canon/Optional: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Canon cameras use a reference image to set a custom WB. A memory card is required.
    • Take a picture of your workspace without any objects; it must be empty and have no outside elements to affect the WB. Full auto can be used.
    • Put the camera in one of the 4 manual modes (P/A/S/M). Select the red menu (Menu 2), then select Custom white balance.
    • Select the white reference photo. Press SET on the camera. Once this is done, the camera will save the custom white balance.
    • Mirrorless: I DO NOT USE NIKON CAMERAS, so I do not have a demo camera. From the limited research I have done, it looks like all Z cameras use the same steps: Nikon Z5
    • DSLR: I DO NOT USE NIKON CAMERAS, so I do not have a demo camera. From the limited research I have done, there are at least 3 common layouts: (Note: instructions very generalized): Nikon D5600 (entry level-midrange) Nikon D810 (high end)
  7. Basic - How to setup a photo studio to take better photos, Making a backdrop: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Making a backdrop: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Making a backdrop: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • THIS STEP SHOWS TWO EXAMPLE SETUPS. As long as there is no nonwhite background visible (or it is correctable in post), build this how you see fit.
    • When using posterboard, use the MATTE side. Glossy materials and light do not mix, and reflect light in ways not found with matte materials.
    • Setup a backdrop support. This can be anything from a trifold board cut in half (the style you used in "school") or a custom design. I chose a custom design to conform it to my design spec and make the modifications I wanted.
    • Setup your white background. Once the backdrop is stable, minimize as many unsightly areas as possible. You are ready.
    • Take a few test photos (Optional). If you are unsure about the end result, take 1-2 test shots for review. Make adjustments until you are happy with the end result.
  8. Basic - How to setup a photo studio to take better photos, Wood backdrop (small spaces): crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Wood backdrop (small spaces): crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Wood backdrop (small spaces): crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Authors note: Reinforce your hinges, or do the hinge mounting internally (L bracket) and externally and just deal with the bump - I had to break this one down due to shoddy assembly work catching up to me. I will rebuild this in the future and show how to get it right.
    • I have already assembled this one, but assembly is simple.
    • Place a few support brackets on the lower piece. Add screws as your brackets permit.
    • Hold the top piece up and add screws to the top side.
    • Once assembled, you are ready to use the backdrop.
  9. Basic - How to setup a photo studio to take better photos, Photo Editing: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Photo Editing: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Basic - How to setup a photo studio to take better photos, Photo Editing: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Affinity Photo (Paid): My preferred choice due to RGB/8/16/32, CMYK, LAB/16, and TIFF RGB/32 color mode support and better high-end printer support. This also has features only found in CC/Legacy CS or full features which are automatic only in PSE. This is a one-time purchase; major upgrades are paid.
    • Photoshop Elements (Paid): For most people, this is sufficient but with limitations NOT FOUND in CC/Legacy CS: Advanced functions are automatic only and only supports RGB/8/16* (*downgrades to RGB/8). HDR RGB/32 support is limited to JPG files. While it "works", there are restrictions not found in other programs or CC.
    • AVOID ADOBE DIGITAL LICENSES. THESE ARE PLATFORM LOCKED AND COST THE SAME AS THE PHYSICAL MULTIPLATFORM LICENSE.
    • DXO PhotoLab (Paid): This is similar to Lightroom before Adobe discontinued non-Saas Lightroom. This is a one-time purchase (3-seat license). I used the trial for this guide.
    • BEWARE: LIFETIME MEANS INITIAL REQUIREMENTS AT TIME OF PURCHASE. This may not survive a major system upgrade!
    • Luminar Neo (Paid): This application is primarily AI driven. It can be purchased one-time or as a subscription. Subscriptions include all extensions (not included with one-time purchase).
    • Free (Mac): There are fewer free Mac programs. However, Darktable (Gatekeeper bypass required) and GIMP run on Macs. There are also free apps in the App Store (NOTE: Most App Store apps push subscriptions!)
    • Free (Windows): For Windows users, there are significantly more free apps available outside of App Stores. For example paint.net is Windows only, while GIMP and Darktable are available for Windows and Mac.
Nick
crwdns2935283:011/10/09crwdne2935283:0
94,839 crwdns2915208:0crwdne2915208:0
crwdns2935297:059crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0326crwdne2931471:0
crwdns2935297:01,381crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,436
