Badger Patriot 105 Needle and Head Replacement
  1. Badger Patriot 105 Needle and Head Replacement, Needle and Head: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Inspect your needle for visible damage.
    • Any bend in the needle will affect the flow and pattern of paint from the airbrush.
  2. Badger Patriot 105 Needle and Head Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disassemble your airbrush beginning with the needle. Each piece is held on with threading, so carefully unscrew each part one at a time by hand.
    • Make sure to work on a flat, clear surface to easily keep track of small and delicate parts.
    • Every part should be removed and broken down as far as possible, as paint buildup can occur in unexpected places.
  3. Badger Patriot 105 Needle and Head Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Inspect the size and type of your needle head. This will help you to order a proper replacement.
    • The head on the right is for the Badger 105, and the head on the left is for a much smaller and finer Badger Sotar 20/20.
  4. Badger Patriot 105 Needle and Head Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While your airbrush is disassembled, you may also want to replace the rubber o-ring present at rear of the brush assembly. The o-ring can be removed easily by hand, or a small flat-head screwdriver may be used to pry it off.
    • If you do not wish to replace it, make sure to remove it before cleaning the components with alcohol as soaking rubber in alcohol will cause the rubber to become brittle and inflexible.
  5. Badger Patriot 105 Needle and Head Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Badger Patriot 105 Needle and Head Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Badger Patriot 105 Needle and Head Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • It is best to work somewhere that you will be able to easily find the head if it drops. Hold the airbrush body so that the head nesting is facing upwards.
    • Carefully set the new needle head in the nest, then screw the tip assembly on top, making sure the tip of the head is aligned with the hole in the tip assembly.
  6. Badger Patriot 105 Needle and Head Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert your new needle into the needle action assembly.
    • Make sure that the needle-holding nut is loosened to allow the needle to enter the assembly, and then tightened it to allow the needle to be moved by the trigger.
  7. Badger Patriot 105 Needle and Head Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To prevent any future damage to the needle, always retract the needle into the airbrush when not in use.
  8. Badger Patriot 105 Needle and Head Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that the needle and head have been replaced, your airbrush is ready for use again.
Cameron Davis
crwdns2935283:009/18/21crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
York University, Team E-5, Melo-Thaiss Fall 2021 crwdns2935289:0York University, Team E-5, Melo-Thaiss Fall 2021crwdne2935289:0
YORK-MELO-THAISS-F21SEG5
crwdns2942667:0crwdne2942667:0 1,893
