Arlo Ultra 2 Camera Lens Replacement
Xavier Feaster-Rivera
crwdns2944107:0crwdnd2944107:0Xavier Feaster-Riveracrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 16, 2024crwdne2944111:0
35 - 50 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
If the camera lens on your Arlo Ultra 2 is not functioning properly. For issues such as a blurry image you will want to refer to the troubleshooting guide before replacing the Camera lens. In this guide you will replace the camera lens on your Arlo Ultra 2 camera. The camera lens is what records on the Arlo Ultra 2, and if it is not working properly it's important that it be replaced if the troubleshooting steps did not resolve your problem.
crwdns2944105:0crwdne2944105:0
  1. Arlo Ultra 2 Camera Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the button on the bottom of the camera to release the case.
    • Pull the white case off of camera.
  2. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the white cube shaped battery from the back to remove it from camera.
  3. Arlo Ultra 2 Camera Lens Replacement, Speaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement, Speaker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity. They are found in each corner.
  4. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, loosen and remove the camera faceplate.
  5. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, loosen and remove the back casing to expose the camera hardware.
  6. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Very gently, pry the circuit boards apart from the white connector, removing the upper circuit board.
  7. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove two 5.0 mm screws from the metal bracket.
    • Use a spudger to separate the long metal bracket.
    • There is an arrow etched into the bracket. It points towards the top of the camera. This is important when reassembling the camera.
  8. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each ZIF connector. Then, you can safely pull the cables out.
    • Be sure to pry up on the hinged flap, not the connector socket.
  9. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to carefully push on each side of the speaker cable connector until it's out of its socket.
  10. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the small green circuit board.
  11. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Feed the speaker cable through the opening to remove the speaker.
  12. Arlo Ultra 2 Camera Lens Replacement, Camera Lens: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement, Camera Lens: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement, Camera Lens: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two 5.0 mm screws from both sides of the metal plate.
    • Pry the metal plate away from circuit board underneath.
    • There is a small amount of blue putty in between the metal plate and the circuit board.
  13. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to remove the entire green circuit board with lens attached.
  14. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove three black 5.0 mm screws from back of the circuit board.
    • Separate the lens from the circuit board.
    • There is a small cord connecting the lens and circuit board.
  15. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to carefully push on each side of the white cable connector to remove it from the socket and separate the camera lens from the board.
  16. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two 4.0 mm screws from the side of the lens body.
  17. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the blunt tweezers to remove the focus motor control insert from the main lens body.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
crwdns2935283:001/23/23crwdne2935283:0
449 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team 1-4, Karnes Winter 2023 crwdns2935289:0Linn Benton Community College, Team 1-4, Karnes Winter 2023crwdne2935289:0
LBCC-KARNES-W23S1G4
crwdns2947412:07crwdne2947412:0
Any ideas on where to get the lens ordered?
Jerald Buechler - crwdns2934203:0crwdne2934203:0
I called Arlo and they said they don’t sell a replacement. I couldn’t find it anywhere online either. Does anybody know where to get a replacement?
Barry Bonds - crwdns2934203:0crwdne2934203:0
My was badly scratched and I would like to replace the lens but I can't find any arlo lenses for sale. Plenty other ones but not arlo one.
Karol jar - crwdns2934203:0crwdne2934203:0
Has anyon found where to buy a replacement lens? Mine is cracked and unusable without a new lens.
Digit Holder - crwdns2934203:0crwdne2934203:0
My Arlo ultra lens fell out and smashed whilst swapping out the battery, the inertia from the tap dislodged the poorly fix lens, now I cant find a replacement
Paul Heslin - crwdns2934203:0crwdne2934203:0
Unfortunately, not much help without a source for replacement part.
troykirchenbauer - crwdns2934203:0crwdne2934203:0
Die Demontage-Anleitung ist leider nicht zu gebrauchen wenn es keine Ersatzteilquelle gibt. Schade.
Marco Thamm - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 87
crwdns2942667:0crwdne2942667:0 1,705
