Apple Watch Series 2 Force Touch Gasket Replacement
  1. Apple Watch Series 2 Force Touch Gasket Replacement, Power off your Apple Watch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement, Power off your Apple Watch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  2. Apple Watch Series 2 Force Touch Gasket Replacement, Apply heat: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare an iOpener (or grab a hair dryer or heat gun) and heat the face of the watch until it's slightly too hot to touch.
    • Leave the iOpener on the watch for at least a minute to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener, or move it around on the screen as sections cool, to heat the screen enough to pry it off.
  3. Apple Watch Series 2 Force Touch Gasket Replacement, Observe all warnings: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement, Observe all warnings: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement, Observe all warnings: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Safety Glasses
    $3.19
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
  4. Apple Watch Series 2 Force Touch Gasket Replacement, Pry up the screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement, Pry up the screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement, Pry up the screen: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
    • Do not insert the knife more than 1/16th of an inch (~2 mm).
  5. Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
    • Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
    • Don't try to fully open or detach the display yet.
  6. Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
    • iFixit screen and battery repair kits include a replacement Force Touch gasket, so don't fret too much if yours is damaged.
    • Otherwise, to preserve the Force Touch gasket, pry carefully under the edge of the display. If the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
    • Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
    • Don't insert the opening pick deeper than 1/16th of an inch (~2 mm).
  7. Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To avoid straining the display cables, don't open the display all the way yet.
    • Open the display to about a 45° angle, and use tweezers to peel off the adhesive between the display and the Force Touch gasket.
    • Thread the adhesive around and behind the display cables to get it off completely.
  8. Apple Watch Series 2 Force Touch Gasket Replacement, Battery Disconnection: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement, Battery Disconnection: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Y000 driver to remove the Tri-point screw securing the metal battery connector cover.
    • Remove the cover.
  9. Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery by prying its connector straight up with the edge of a pry tool.
    • Bend the connector up slightly to make sure it does not make contact by accident.
  10. Apple Watch Series 2 Force Touch Gasket Replacement, Force Touch Gasket: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement, Force Touch Gasket: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a pry tool to disconnect the Force Touch gasket by prying it straight up from the outside edge.
    • The connector you unplug actually leads to the motherboard. The socket underneath that connector lies on the Force Touch gasket itself.
  11. Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the connector plate of the Force Touch gasket.
    • Slide your tweezers or a pry tool underneath the gasket to separate the glue underneath.
    • Separate the glue all around the perimeter of the watch except the edge where the display cables lie, to avoid ripping them by accident.
  12. Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull the Force Touch gasket over and around the display.
    • If the display is already detached because you're replacing it, it's easier to leave the new display disconnected for now. Connect the display after the Force Touch gasket is replaced (five steps down).
    • Flip the display almost shut so that you can safely peel the Force Touch gasket from the remaining edge.
    • Remove the Force Touch gasket.
  13. Apple Watch Series 2 Force Touch Gasket Replacement, Cleaning the case: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement, Cleaning the case: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Adhesive Cleanup Kit (Set of 12)
    $7.99
    • Apply a little bit of isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove any remaining adhesive from the former force touch gasket.
    • To remove the adhesive on the side under the display cables, hold the display nearly closed and pull it gently away from the edge while you clean it.
  14. Apple Watch Series 2 Force Touch Gasket Replacement, Cleaning the display: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement, Cleaning the display: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the watch upside-down so the display lays flat while slightly lifting up the case.
    • Carefully remove any remaining adhesive from the back of the display.
  15. Apple Watch Series 2 Force Touch Gasket Replacement, Installing the new gasket: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to carefully remove the protective liner from the bottom of your new Force Touch gasket, exposing the adhesive underneath.
    • Make sure the gasket is oriented with the connector pins facing away from you, or you'll remove the liner from the wrong side.
  16. Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the Force Touch gasket diagonally to thread it over the display.
    • Slightly tilt the display forward so you can align the Force Touch gasket with the frame.
    • Starting on the corner opposite the Force Touch gasket connector, set the gasket onto the frame, and press it down.
  17. Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pry tool to fold the connector plate of the Force Touch gasket down into its recess.
    • Reconnect the flex cable by pressing it down gently.
  18. Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure your display is connected before you reconnect the battery.
    • Use the point of a spudger to bend the battery connector back into its original position.
    • Gently press down to reconnect the battery flex cable.
  19. Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to place the metal plate covering the battery connector back in its original position.
    • Install the Tri-point #000 screw.
    • At this point you might want to turn on the watch and check if everything is working, before sealing it shut.
  20. Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to gently remove the protective film on top of the Force Touch gasket.
  21. Apple Watch Series 2 Force Touch Gasket Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the display and press it down firmly onto the adhesive.
    • To improve bonding of the adhesive you can use an iOpener to warm up the display. Then apply some pressure for a few hours (placing it under one or two heavy books overnight might be a way).
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
crwdns2935229:050crwdne2935229:0
Tobias Isakeit
crwdns2935283:003/31/14crwdne2935283:0
125.874 crwdns2915208:0crwdne2915208:0
crwdns2935297:0189crwdne2935297:0
Tobias Isakeit - Repairability Engineer crwdns2935289:0Tobias Isakeit - Repairability Engineercrwdne2935289:0
Business
crwdns2935297:01.137crwdne2935297:0
crwdns2947412:07crwdne2947412:0
Hola, Me presento como nuevo y NOVATO. Me llamo Jaime, y Yo creo que os mereceis un 10. La caña de España.
Jaime Villa - crwdns2934203:0crwdne2934203:0
Hola Jaime! Bienvenido! Muchas gracias por tu comentario. Nos alegra que te guste nuestro sitio. Cualquier duda que tengas, no dudes en consultarme. Soy la moderadora y líder de la comunidad hispanohablante.
Mariana Roca -
The gasket comes with all the necessary adhesive or you need to put he the sealing adhesive separately? I need to replace my screen and I got the gasket and screen but don’t know if I need glue to waterproof it?
Jose F - crwdns2934203:0crwdne2934203:0
I bought iFixit’s battery replacement kit and the gasket which I received had adhesive on both sides, just like in this guide.
The repair kit does comes with extra gasket adhesive, which confused me at first. The extra adhesive is included in case you manage to open the watch without damaging the original gasket.
dalexgray -
I have no idea why they include the extra adhesives. When I tried to use one the screen sat too high and it looked bad.
Donald Fournier -
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 189
crwdns2942667:0crwdne2942667:0 28,069
