Apple TV 4K Logic Board Replacement
Keenan Barber
crwdns2944107:0crwdnd2944107:0Keenan Barbercrwdnd2944107:0crwdnd2944107:0crwdnd2944107:06crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Nhl 23, 2023crwdne2944111:0
7 - 10 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2862591:0crwdne2862591:0
crwdns2942287:0crwdne2942287:0
This guide will show you how to properly get into your Apple TV 4K device and get access to the logic board for replacement.
crwdns2944105:0crwdne2944105:0
  1. Apple TV 4K Logic Board Replacement, Logic Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
    • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
    There are three clips on each side - short after the beginning of the rounding on each side, and one middle.
    The bottom panel is approx 5mm in height and a little bit flexible.
    hackgreti - crwdns2934203:0crwdne2934203:0
  2. Apple TV 4K Logic Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple TV 4K Logic Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
    • Four 10 mm screws
    • Lift and remove the heat sink assembly from the device.
    On my model these where T7 Torx.
  3. Apple TV 4K Logic Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple TV 4K Logic Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use plastic spudger to pull up on all three antenna connectors to remove them.
    • Remove rubber piece from front side of device.
  4. Apple TV 4K Logic Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the following screws holding the logic board in place using the T7 Torx:
    • Two black 3 mm screws
    • Two silver 4 mm screws
  5. Apple TV 4K Logic Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple TV 4K Logic Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple TV 4K Logic Board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up logic board. Try lifting it up from the front side.
    • Remove logic board and set aside.
crwdns2935229:010crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Keenan Barber
crwdns2935283:010/04/18crwdne2935283:0
1,297 crwdns2915208:0crwdne2915208:0
UW Stout, Team S6-G3, Ogden Fall 2018 crwdns2935289:0UW Stout, Team S6-G3, Ogden Fall 2018crwdne2935289:0
UWSTOUT-OGDEN-F18S6G3
crwdns2947412:08crwdne2947412:0
Where does one get a new logic board??
MP94025 - crwdns2934203:0crwdne2934203:0
Any idea on where I can purchase. new logic board?
tylerchumchal - crwdns2934203:0crwdne2934203:0
Where do you buy the board…….
Andy Grichtmeier - crwdns2934203:0crwdne2934203:0
Good job on showing how to remove and replace logic board. Now as the other three commentators have asked
, where can you buy another one or is an exercise in futility
Kanehoe - crwdns2934203:0crwdne2934203:0
Hm. Has anyone’s Apple TV 4k logic board failed?
oTWR - crwdns2934203:0crwdne2934203:0
You’ll only be able to buy replacement boards on eBay or similar. I have successfully repaired a number of Apple TV 4K that had no power issues by fixing various shorted components.
sinkproductions - crwdns2934203:0crwdne2934203:0
Currently not possible to buy the board. But you can buy the power supply here. We have seen many problems with random restarting of apple TV 4K. Solution is to repair the board chip.
LagaiPhone - crwdns2934203:0crwdne2934203:0
Hello I can not get my remote to connect with my Apple TV and even when I changes remote.
What should I do this happen 3 times to me.
Thank
Dwg - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 111
crwdns2942667:0crwdne2942667:0 9,864
