This guide will show you how to properly get into your Apple TV 4K device and get access to the logic board for replacement.
Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
Four 10 mm screws
Lift and remove the heat sink assembly from the device.
Use plastic spudger to pull up on all three antenna connectors to remove them.
Remove rubber piece from front side of device.
Unscrew the following screws holding the logic board in place using the T7 Torx:
Two black 3 mm screws
Two silver 4 mm screws
Use a spudger to pry up logic board. Try lifting it up from the front side.
Remove logic board and set aside.
crwdns2935229:010crwdne2935229:0
crwdns2947412:08crwdne2947412:0
Where does one get a new logic board??
Any idea on where I can purchase. new logic board?
Where do you buy the board…….
Good job on showing how to remove and replace logic board. Now as the other three commentators have asked
, where can you buy another one or is an exercise in futility
Hm. Has anyone’s Apple TV 4k logic board failed?
You’ll only be able to buy replacement boards on eBay or similar. I have successfully repaired a number of Apple TV 4K that had no power issues by fixing various shorted components.
Currently not possible to buy the board. But you can buy the power supply here. We have seen many problems with random restarting of apple TV 4K. Solution is to repair the board chip.
Hello I can not get my remote to connect with my Apple TV and even when I changes remote.
What should I do this happen 3 times to me.
Thank
There are three clips on each side - short after the beginning of the rounding on each side, and one middle.
The bottom panel is approx 5mm in height and a little bit flexible.
hackgreti - crwdns2934203:0crwdne2934203:0
