Apple IIc IC Chips Replacement
crwdns2942287:0crwdne2942287:0This guide will help you re-seat or replace the IC chips on the computer's mother board. The IC chips, or Integrated Circuit chips, are used to perform various vital functions on the computer. Chips coming unseated or going bad is a common problem with the Apple II series and is easily fixed or replaced. Re-seating your chips will helpful if you are having trouble running your computer.
Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
Release the catch by pushing it in using a plastic opening tool.
Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
This step is wrong. The ports cover should be removed with a plastic disassembly tool first. Failure to do this will lead to a set of broken plastic hooks.
Lift the handle straight up to remove.
Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive.
Carefully detach ribbon connector from floppy disk drive by pulling it out horizontally.
Unscrew the four 8.5 mm screws that attach the floppy drive cage. Two screws are located on the front and back of the cage.
There is actually no need to remove the cage in order to lift the floppy drive.
Carefully lift the floppy drive cage straight up to remove it.
Lift the floppy drive straight up to remove.
Did I miss something?
Why take the cage off the drive when you are just going to take the drive out to get it out of the way?
Thanks.
Use the plastic opening tools to carefully lever the IC chips out of the holder. Gently lever one end and then the other to lift it out of the chip holder.
crwdns2935229:09crwdne2935229:0
What are the 4 round black things shown in the photos in Step 1 and Step 6? (No explanation is given.)
