Apex TM772 Battery Replacement
  1. Apex TM772 Battery Replacement, Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by inserting the plastic opening tool into the seam between the back and front of the case and carefully pry the back from the front.
  2. Apex TM772 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Moving along the seam continue to pry the case apart.
    • The internal speaker is adhered to the inside of the back casing. There are two wires that connect the speaker to the circuit board and may be damaged if care is not taken. Once open the speaker may be removed from the back casing by removing the tape holding the speaker with either tweezers or your fingers.
  3. Apex TM772 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
  4. Apex TM772 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Plastic Cards
    $2.99
    • Do Not use metal tools to remove the battery as the battery is soft and pliable. Use extreme caution to avoid damage to the battery if it needs to remain intact. Use a plastic card or nylon tool to remove battery from adhesive.
    • Using tweezers or your fingers, remove the yellow tape from the battery.
    • Using a plastic card or nylon tool, carefully separate battery from case by sliding the tool under battery to loosen adhesive.
  5. Apex TM772 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • For soldering instructions, refer to the iFixit Soldering Guide
    • To remove battery, Locate the soldering points where the three wires are connected. Desolder these attachments from the motherboard.
  6. Apex TM772 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solder the wire connection of the red wire to the positive (+) position on the left
    • Solder the wire connection of the yellow wire to the center position that is slightly above the positive (+) and the negative (-) positions. This is the ground.
    • Solder the wire connection of the black wire to the negative (-) position on the right.
Doran Van Bemmel
crwdns2935283:004/12/17crwdne2935283:0
601 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S2-G6, Rowley Spring 2017 crwdns2935289:0Eastern Washington University, Team S2-G6, Rowley Spring 2017crwdne2935289:0
EWU-ROWLEY-S17S2G6
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 413
