Anker SoundCore 2 Battery Replacement
  1. Anker SoundCore 2 Battery Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker SoundCore 2 Battery Replacement, Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
    How do i put the front plate back on
    Hardstarling - crwdns2934203:0crwdne2934203:0
  2. Anker SoundCore 2 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker SoundCore 2 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker SoundCore 2 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove eight 10 mm screws from the speaker mount using a Phillips #1 screwdriver (Phillips #0 can strip the screw heads).
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Be careful not to damage the rubber gasket around the speaker mount plate.
    • Use your hand to remove the speakers. Some variants have a wire from the speaker to the board, some rest on contact pins.
  3. Anker SoundCore 2 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker SoundCore 2 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker SoundCore 2 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #1 screwdriver. Some variants have 2 screws.
    • Carefully remove the bluetooth antenna wire from the left of the board. It pulls up without much pressure.
    • Flip up the motherboard to expose the battery.
  4. Anker SoundCore 2 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker SoundCore 2 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a nylon spudger to remove the battery from the speaker casing.
    • Caution: Do not use metal prying tools on a battery—these can puncture an unprotected battery, potentially causing a fire.
    • The battery is glued down so it may be difficult to remove.
  5. Anker SoundCore 2 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker SoundCore 2 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the wire that connects the battery with the motherboard.
    • Battery specs: 2 x 18650 2600mAh soldered in series (to bring voltage to 7.4V).
    • Can safely be upgraded to 2 x 18650 3500mAh for additional capacity.
    • When replacing the battery, plug in the new battery where the old one was plugged in.
Tripp Lersch
crwdns2935283:001/14/21crwdne2935283:0
408 crwdns2915208:0crwdne2915208:0
Illinois Wesleyan University, Team S1-G2, Bullock Spring 2021 crwdns2935289:0Illinois Wesleyan University, Team S1-G2, Bullock Spring 2021crwdne2935289:0
IWU-BULLOCK-S21S1G2
crwdns2947412:07crwdne2947412:0
It would be nice to have the specifications of the battery so availability can be checked before disassembly.
Michael Anderson - crwdns2934203:0crwdne2934203:0
7.2V, 2550 mAh, 18.36 Watt - Hour
Kang Le - crwdns2934203:0crwdne2934203:0
Hey I had a question.So i kind of dipped anker sound core 2 in water eithout the charging cover on and now it wont turn on.Can you Help what might be the problem here?
abdurreheembakir - crwdns2934203:0crwdne2934203:0
Akku SoundCore2
Kapazität 2600 mAh Leistung 19.24 Wh Spannung 7.4 V Typ Li-ion
Andreas Reheis -
Habe ihn mir mit 2 18650/3500mA Akkus von Temu selber gebaut. Lädt zwar jetzt länger und hält aber auch 20% länger. Dabei aufpassen und die Kabel an den Akkus wieder richtig anlöten. Wegen der Li-Ionen Ladeautomatik auf der Hauptplatine. Am Ende in einen passenden Schrumpfschlauch stecken und aufpassen das rundum kein Kurzschluss passieren kann.
Gevatter Tod - crwdns2934203:0crwdne2934203:0
Können Sie mir bitte sagen, welche Form die Kontakte eines 18650-Akkus haben müssen, um ihn neu zu löten?
Oleg M -
Phillips #1 won't strip the screw like a #0 can.
Mike - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 26
crwdns2936753:07crwdne2936753:0 154
crwdns2936753:030crwdne2936753:0 600
crwdns2942667:0crwdne2942667:0 16,875
