If your Anbernic RG353V handheld game won't turn on even after you've charged it or replaced the battery, it may have a damaged or faulty motherboard. This guide demonstrates how to replace the motherboard of your device.
Use a 2 mm Hex screwdriver to remove the six 7 mm screws from the back case of the handheld game.
Use an opening tool to pry the top and bottom of the game apart. Work the tool around the perimeter of the device between the seam to release the snap tabs.
Separate the top and bottom cases gently.
Push on alternating sides of the connector to disconnect the battery wire from the main circuit board.
If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
To disconnect the cable coaxial cable, slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the board.
Use a Phillips #00 screwdriver to remove the five 7 mm Phillips from the plate covering the bottom of the circuit board.
Remove the black cover.
Use a Phillips #00 to remove the four 6 mm screws attaching the thumbsticks to the circuit board.
Use a spudger to flip up the locking flaps of the ZIF connectors.
Use tweezers or your fingers to gently pull the red ribbon cables out of their sockets.
Use a spudger to flip up the locking flap of the ZIF connector.
Use tweezers or your fingers to gently pull the bronze-colored ribbon cable out of its socket.
Use tweezers or your fingers to remove the small black ribbon cable from the socket.
Use a Phillips #00 screwdriver to remove the four 5 mm screws that secure the circuit board to the case.
Carefully remove the circuit board by pulling it upward and away from the case.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%). Take your e-waste to an R2 or e-Stewards certified recycler.
