Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement
  1. Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, power off your device completely and disconnect from the charging adapter.
    • Flip the laptop over so the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove ten 5.6 mm screws from the back panel.
    • Place the end of an opening tool in the seam between the bottom and top case and slide it around the perimeter to release the clips holding it together.
    • Use a few opening picks in the seam to keep the clips from reattaching.
    • Remove the back panel.
  2. Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket on the motherboard.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
    • Lift the battery upwards to remove it from the device.
  3. Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement, Fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement, Fan: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the end of a spudger to push on alternating sides of the sliding connector and remove it from the socket on the motherboard.
  4. Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws attaching the fan to the chassis.
    • Slide the fan out from the socket to remove it.
  5. Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement, Speakers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement, Speakers: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To disconnect the speaker cable, use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • Don't pull on the cables.
  6. Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the speaker wire from routing guides.
    • The wire may also be attached to the chassis with adhesive.
    • Remove the speakers and wire that connects them from the laptop.
  7. Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement, Wi-Fi Card: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement, Wi-Fi Card: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the white coaxial cable connector (as close to the head as possible) and lift straight up from the board.
    • Repeat to disconnect the black coaxial cable connector.
  8. Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the 2 mm screw securing the Wi-Fi card to the motherboard.
    • Slide the Wi-Fi card out from the socket.
  9. Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger or a clean fingernail to flip up the locking flap on the four ZIF connectors—this is the unlocked position.
    • Use tweezers or your fingers to gently pull each cable out of its socket.
    • Try pushing on alternating sides of the CMOS battery connector with a spudger to disconnect it from the socket.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • To disconnect the display connector, first, gently push the tip of a spudger under the metal buckle to unclip it, then swing it over the socket.
    • Next, hold the buckle and cable together and gently pull the connector straight out of its socket.
    • Use the point of a spudger to push on alternating sides of the power connector to "walk" it out of its socket.
    • Don't pull on the wires or you risk damaging the connector and device.
  10. Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the four screws from the hinge.
    • Lift the hinge to allow the motherboard to be removed.
  11. Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the four screws securing the motherboard to the chassis.
    • If your replacement board does not come with a heat sink, remove the three screws in descending order of the inscribed numbers on the heat sink.
    • If you aren't replacing the heat sink, loosen the screws before removing the motherboard.
    • Lift the motherboard from the laptop.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Knicholas Taylor
crwdns2935283:002/10/25crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-5, Kilpatrick Spring 2025 crwdns2935289:0University of North Texas, Team 1-5, Kilpatrick Spring 2025crwdne2935289:0
UNT-KILPATRICK-S25S1G5
crwdns2936753:030crwdne2936753:0 67
crwdns2942667:0crwdne2942667:0 181
