Acer Aspire 3 A315-24P-R7VH Motherboard Replacement
  1. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Power off your laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shut down your laptop and unplug any cables.
  2. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the back cover screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the laptop and flip it over on a flat, clean surface.
    • Use a Phillips screwdriver to remove the eleven 6.6 mm‑long screws from the back cover.
  3. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the long edge of an opening pick straight down between the chassis and the back cover at the rear of the laptop
    • Pry up to release a few back cover clips and position the opening pick flat under the back cover.
    • Slide the pick along the rear edge of the laptop to release the clips.
  4. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry around the entire perimeter until the back cover releases.
  5. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the back cover off the chassis and remove it.
    • If the back cover is stuck, repeat the previous step to release any remaining clips.
  6. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Peel back the tape: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Peel back the tape: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to peel away the tape covering the battery connector.
  7. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to push down on either side of the battery cable connector until it comes out of its socket.
  8. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the battery screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the battery screws: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 4.7 mm‑long screws securing the battery.
  9. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the battery: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the battery out of the chassis and remove it.
  10. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the right speaker: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the right speaker: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the right speaker: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger to push down on either side of the right speaker cable connector until it comes out of its socket.
    • The right speaker is on the left-hand side since your laptop is upside down.
  11. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the left speaker: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the left speaker: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the left speaker: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the same procedure for the left speaker.
  12. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the WLAN card cables: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the WLAN card cables: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the WLAN card cables: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide one arm of your angled tweezers under the metal neck of the white cable on the WLAN card.
    • Lift the metal neck to disconnect the cable.
    • Repeat the same process for the black cable.
  13. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Reassembly Information: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When reassembling, use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. It may take multiple tries repositioning the head until it reconnects.
    • Don't try to force the connector into place or you may permanently damage it.
  14. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the WLAN card screw: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the WLAN card screw: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the 2.2 mm‑long screw from the WLAN card.
    • The WLAN card will pop up at a slight angle with the screw removed.
  15. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the WLAN card: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the WLAN card: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the WLAN card out of its socket and remove it.
    • During reassembly, insert the WLAN card at a slight downward angle into its socket.
  16. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the SSD screw: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the SSD screw: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the one 4.9 mm‑long screw securing the SSD.
  17. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the SSD: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the SSD: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the SSD by its edges and pull it straight out of its socket to remove it.
    • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
  18. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the fan: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the fan: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to push down on either side of the fan cable connector until it comes out of its socket.
  19. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the fan screws: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 5.6 mm‑long screws that are securing the fan.
  20. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the fan: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the fan: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the fan: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the fan out of the chassis and remove it.
  21. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the heat sink screws: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the heat sink screws: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Starting with the screw labeled 1 and going in order, use a Phillips screwdriver to remove the three 4.7 mm‑long screws that secure the heat sink.
    • During reassembly, tighten the screws in the same order as you removed them.
  22. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the heat sink: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the heat sink: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the heat sink to separate the thermal paste bonding it to the motherboard.
    • Remove the heat sink.
    • Before installing a new heat sink, follow this guide to clean the CPU and heat sink and reapply thermal paste.
  23. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the display: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the display: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the display: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger to push down on either side of the display cable connector until it comes out of its socket.
  24. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the DC-IN connector: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the DC-IN connector: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to push the indent on DC-IN cable connector until it comes out of its socket.
  25. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the USB board: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the USB board: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger or a fingernail to lift the locking tab on the USB board ZIF connector.
  26. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers or your fingers to grasp the blue pull tab and gently pull the cable out of its socket.
    • This cable is very fragile, try not to crease or kink the cable.
  27. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the keyboard: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the keyboard: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger or a fingernail to lift the locking tab on the keyboard ZIF connector.
  28. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This cable is very fragile, so be careful not to crease or fold the cable.
  29. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the touchpad: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the touchpad: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger or a fingernail to lift the locking tab on the touchpad ZIF connector.
  30. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  31. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the lid sensor cable: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the lid sensor cable: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger or a fingernail to lift the locking tab on the lid sensor ZIF connector.
  32. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  33. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the RTC Battery: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the RTC Battery: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Disconnect the RTC Battery: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger to push on either side of the RTC battery cable connector and "walk" it out of its socket.
    • This connector can be difficult to loosen. Take your time and work slowly.
  34. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the motherboard screw: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the motherboard screw: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the 4.7 mm‑long screw securing the motherboard.
  35. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Remove the motherboard: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard out of the frame and remove it.
Take your e-waste to an R2 or e-Stewards certified recycler. Acer partners with different e-waste recycling programs that vary by region, click here to see where you can properly dispose of your e-waste.
Kara Piepenbrink
crwdns2935283:005/31/24crwdne2935283:0
4 861 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 807crwdne2935297:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 94
