ASUS TUF Dash F15 Lower Case Replacement
  1. ASUS TUF Dash F15 Lower Case Replacement, Unfasten the lower case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS TUF Dash F15 Lower Case Replacement, Unfasten the lower case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS TUF Dash F15 Lower Case Replacement, Unfasten the lower case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 14 Phillips screws securing the lower case:
    • Seven 8.8 mm screws
    • Seven 10.1 mm screws
    • Use a Phillips screwdriver to loosen the captive screw.
    • Loosening this captive screw will pop up and separate the bottom-right corner of the back cover from the chassis.
    • During reassembly, tighten the captive screw before the rest of the screws.
  2. ASUS TUF Dash F15 Lower Case Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS TUF Dash F15 Lower Case Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the lower case and the chassis on the front right edge near the captive screw.
  3. ASUS TUF Dash F15 Lower Case Replacement, Release the clips: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS TUF Dash F15 Lower Case Replacement, Release the clips: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS TUF Dash F15 Lower Case Replacement, Release the clips: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick along the front edge to release the clips securing the lower case.
    • Repeat this process along the perimeter of the lower case to release the remaining clips.
  4. ASUS TUF Dash F15 Lower Case Replacement, Remove the lower case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS TUF Dash F15 Lower Case Replacement, Remove the lower case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS TUF Dash F15 Lower Case Replacement, Remove the lower case: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
    do you know how wide is this screw cuz i have a problem with finding them for cheap because on asus site they are 15dollars but the deliviery is 50 dollars and thats kinda much and i also found universal screws for laptop the lenght is good but i dont know how wide they should be
    Natan Jot - crwdns2934203:0crwdne2934203:0
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our ASUS TUF answers community for help.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
118,962 crwdns2915208:0crwdne2915208:0
crwdns2935297:0838crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,701crwdne2935297:0
do you know how wide the screws are cuz i lost 2 of them and i have trouble buying them and i only found universal scews that are good for lenght but i dont know wide
I also lost some screws :S
Eric Sanchez -
I'm missing two of the bigger screws too. I don't think its a coincidence but a mistake 'cause I have opened my laptop twice and the two screws were missing on the first time I opened it.
Joel Poikolainen -
Hi there, I hope you're doing well. I was just wondering if there is any possibility to buy a motherboard of a newer model of this laptop(one that has the same body) and replace it with mine. Because I have the 3050 ti i5 but I would like to upgrade it to i7 3070 version (it seems to have the same shape and size). Do you think this is possible?
Adam - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 179
crwdns2942667:0crwdne2942667:0 5,686
