ANKER SoundCore Charging Port Replacement
Briana Kuo
crwdns2944107:0crwdnd2944107:0Briana Kuocrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 5, 2020crwdne2944111:0
crwdns2931287:020crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
If your ANKER SoundCore does not charge, your charging port may be broken. If you wish to replace your device’s charging port, you can follow this step-by-step guide.
Before attempting to replace anything, it is recommended that you look at this device’s troubleshooting guide.
You will need an iFixit opening tool, Phillips #0 screwdriver, metal spludger, and iFixit opening pick. Soldering experience is needed.
crwdns2944105:0crwdne2944105:0
  1. ANKER SoundCore Charging Port Replacement, Charging Port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ANKER SoundCore Charging Port Replacement, Charging Port: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ANKER SoundCore Charging Port Replacement, Charging Port: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to pry off the screen.
    • Remove the screen from the device.
  2. ANKER SoundCore Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 10 mm Phillips #0 screws from the speaker mount.
  3. ANKER SoundCore Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ANKER SoundCore Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spludger to pry off speaker mount.
  4. ANKER SoundCore Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 8mm Phillips #0 screws from the circuit board.
  5. ANKER SoundCore Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ANKER SoundCore Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the circuit board from the speaker body.
  6. ANKER SoundCore Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ANKER SoundCore Charging Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the iFixit Opening Pick to pry off the charging port cover.
    • Remove the charging port cover.
  7. ANKER SoundCore Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ANKER SoundCore Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the charging port from the circuit board.
    • Solder a new charging port in place of the old one.
    • For help soldering and desoldering, follow this guide.
    Any ideas where we can buy a new charging port?
    sfmann106 - crwdns2934203:0crwdne2934203:0
    This is very informative in so far as to the procedure. It’s far less informative as to where we might obtain a replacement charging port.
    dwesl - crwdns2934203:0crwdne2934203:0
    The Charging port is an USB Mirco Port. To find right part search for JBL FLIP 3 on ebay or other platforms. It is the same part as used for the Anker SoundCore.
    Agi - crwdns2934203:0crwdne2934203:0
    The red box in the picture is highlighting the audio port not the charging port.
    wafflecart - crwdns2934203:0crwdne2934203:0
Briana Kuo
crwdns2935283:002/10/20crwdne2935283:0
311 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S22-G1, Regan Winter 2020 crwdns2935289:0Cal Poly, Team S22-G1, Regan Winter 2020crwdne2935289:0
CPSU-REGAN-W20S22G1
Where can I find a replacement port that is compatible?
tommy2197 - crwdns2934203:0crwdne2934203:0
Mike - crwdns2934203:0crwdne2934203:0
Agi -
Hi I have a Anker soundcore motion plus, the charging port is loose and not charging, it's a usb c, where can I buy that replacement part
.thanks
Justin - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 120
crwdns2942667:0crwdne2942667:0 11,998
