2007-2012 Jeep Patriot Shifter Bushing Replacement
  1. 2007-2012 Jeep Patriot Shifter Bushing Replacement, Removing the Gear Shifter Handle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2007-2012 Jeep Patriot Shifter Bushing Replacement, Removing the Gear Shifter Handle: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the gear shifter handle, where it says PRDL (Park, Reverse, Neutral and Drive) next to it, by pulling it straight out in an upwards direction. It will take some force.
  2. 2007-2012 Jeep Patriot Shifter Bushing Replacement, Remove the Inner Casing of the PRND Bezel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2007-2012 Jeep Patriot Shifter Bushing Replacement, Remove the Inner Casing of the PRND Bezel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the PRND bezel with a flat head screwdriver.
  3. 2007-2012 Jeep Patriot Shifter Bushing Replacement, Remove the Bezel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2007-2012 Jeep Patriot Shifter Bushing Replacement, Remove the Bezel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2007-2012 Jeep Patriot Shifter Bushing Replacement, Remove the Bezel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 19mm screws underneath the bezel using the Phillips #1 screwdriver.
    • Remove the bezel assembly.
  4. 2007-2012 Jeep Patriot Shifter Bushing Replacement, Remove the Screws From the Console: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2007-2012 Jeep Patriot Shifter Bushing Replacement, Remove the Screws From the Console: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 19mm screws from the console using the Phillips #1 screwdriver.
  5. 2007-2012 Jeep Patriot Shifter Bushing Replacement, Remove the Screws From the Storage Compartment: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2007-2012 Jeep Patriot Shifter Bushing Replacement, Remove the Screws From the Storage Compartment: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 19mm screws within the storage compartment using the Phillips #1 screwdriver.
  6. 2007-2012 Jeep Patriot Shifter Bushing Replacement, Opening the Console for Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up on your emergency brake as high as you can get it.
    • Remove the middle and rear section of the console to remove the front section.
    • Grab the sides of the console and start to wiggle it until you hear the sections unsnap from each other.
  7. 2007-2012 Jeep Patriot Shifter Bushing Replacement, Removing the Middle and Back Sections of the Console: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2007-2012 Jeep Patriot Shifter Bushing Replacement, Removing the Middle and Back Sections of the Console: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2007-2012 Jeep Patriot Shifter Bushing Replacement, Removing the Middle and Back Sections of the Console: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the middle and back section back and away from the rest of the console. Completely removing it. You may or may not have some electrical wires you will have to disconnect. It depends on your car's model.
    • You do not have to disconnect this connector from the cigarette lighter.
  8. 2007-2012 Jeep Patriot Shifter Bushing Replacement, Installing the New Bushing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2007-2012 Jeep Patriot Shifter Bushing Replacement, Installing the New Bushing: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2007-2012 Jeep Patriot Shifter Bushing Replacement, Installing the New Bushing: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now you need to be under the shifter bezel on the floorboard. If you follow the rod coming from the transmission, you will see it is not attached to anything.
    • You will see a hole within the rod. That is where your bushing should be. You will push the bushing from the back side of the rod towards the driver side. The bushing should then be facing the driver side. You may need to put a little grease on it as it will be a little difficult to push in. Pliers will help you push it in also.
    • Now that you have the bushing installed, you will reach into the mechanism and clip it in towards the passenger side.
Matt Scamardo
crwdns2935283:002/16/21crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S50-G3, Willis Spring 2021 crwdns2935289:0University of Memphis, Team S50-G3, Willis Spring 2021crwdne2935289:0
UM-WILLIS-S21S50G3
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 92
crwdns2942667:0crwdne2942667:0 5,077
