Prepare the following parts:
4x y_end_caps
8x M4x5 set screws
Engage 2x M4x5 set screws into each of the y_end_caps, on the side with the 2 holes, until they are flush, as shown.
Place one y_end_caps in each of the 4 corners of the Y axis frame. Make sure you orientate them correctly: the single mounting point must be on top.
Tighten each of the 8 grub screws to secure the y_end_caps in place.
2x z_end_caps
4x M4x5 set screws
Engage 2x M4x5 set screws into each of the z_end_caps until they are flush, as shown.
Install the z_end_caps on the exposed ends of the Z axis extrusions. Make sure you orientate them correctly
Tighten each of the 4x set screws to secure the z_end_caps in place.
Prepare the 4 felt pads.
Draw a line as shown in the image.
With pair of scisor, cut the protection on the line and remove the biggest section.
Stick the felt pads on the feet. Orientate them to have the protection on top of the screw.
Download and install the Pano Tuner application (developed by Kaleloft LLC) on your smartphone.
Launch the Pano Tuner app and place your smartphone under the heated bed. Make sure there is no noise in the room that could disrupt the measurement (like a ceiling fan).
Move the Y carriage to the middle of the Y axis.
Pluck the lower portion of the belt to make a sound. Don't pluck it too hard as it might touch the y_belt_holder and distort the sound.
Adjust the belt tension until you have a frequency close to 90Hz (for a standard 6mm belt). Between each adjustment, move the heatbed back and forth along the whole length of the Y axis and then centre it again.
Remove the steel sheet and place a sheet of paper on your heated bed (for protection). Remove any residual filament from the nozzle.
Center your extruder on the X axis. Move it down by rotating both Z lead screws simultaneously. Move the extruder down until the nozzle is just touching the paper.
Stop when the nozzle is just touching the paper.
Place the middle section of a zip tie under the Pinda.
Loosen the M3x10 screw and gently move the PINDA down until it is touching the zip tie.
Tighten the M3x10 screw to secure the PINDA in place.
Plugin and turn on the printer.
Using the screen menu, move the X axis up until it crashes in to the Z tops. The stepper motors will skip, making a noise - this will not damage the motors.
Using the screen menu, move the X axis down until the nozzle is approximately 10-15mm from the heated bed.
If you are using the Bear X axis (BearExxa, BearMera, Bondtech on Bear X axis) or the Original Prusa MK2(S)/MK2.5(S) X axis you need to release the tension on the X smooth rods by unscrewing the tensioning M3x10 screws a few turns. (Note! These are different to the Bear X axis belt tensioning screws.)
Turn off the printer and move the extruder to the centre of the X axis.
Relax the tension of the X axis belt. Refer to the manual for your extruder if you are unsure how to do this. (Note! this was shown in step 06. Z axis motion.)
Loosen the screws which secure the trapezoidal nuts. This is to ensure that the Trapezoidal nuts 'self-centre' on the lead screws.
Make sure the trapezoidal nuts are able to move freely.
Alternating between all 4 screws, incrementally tighten each screw to secure the trapezoidal nuts (alternate between both sides during this process). Don't apply any lateral force to the trapezoidal nuts.
Verify that your X axis pulley is correctly aligned and not touching the X motor.
Bear X axis (BearExxa, BearMera, Bondtech on Bear X axis): tensioner is on the right of the X axis (X end idler).
Original Prusa MK3(S) X axis: tensioner is on the X motor arm.
Original Prusa MK2(S)/MK2.5(S) X axis: there is no tensioner, you can only adjust the tension of the belt on the back of the extruder.
Grip the X motor shaft with pliers to prevent it rotating (grab the flat side of the shaft).
Tension the X axis belt. Do this while trying to move the extruder to the left or right. The belt should stay straight and should not bow up and skip over the drive pulley teeth.
The next step is only if you use the Bear X axis or the Original Prusa MK2(S)/MK2.5(S) X axis.
If you are using the Original Prusa MK3(S) X axis go directly to step 13.
1st image, top left: when the X axis is too short.
1st image, bottom left: when the X axis is too long.
1st image, right: when the X axis is the perfect length.
To adjust the length of the X axis we use the two M3x10 screws of the x_end_idler while looking at the Z tops.
While you tighten the M3x10 screws keep an eye on the Z tops. The M3x10 screws will move the Z lead screws laterally (left or right), adjust them so that the Z lead screws are centred.
Launch the Pano Tuner app and place your smartphone on the heated bed. Make sure there is no noise in the room that could disrupt the measurement (like a ceiling fan).
Move the extruder to the middle of the X axis.
Pluck the lower portion of the belt to make a sound. Don't pluck it too hard as it might touch the x carriage and distort the sound.
Adjust the belt tension until you have a frequency close to 90Hz. Between each adjustment, move the extruder all the way to the left and right and then centre it again.
Original Prusa extruder: you can use the original Prusa firmware available here.
BearExxa needs a custom firmware for calibration: read the guide here.
BearMera can use the Original Prusa firmware (or Bear calibration firmware) with some restrictions: read more in details here.
Bondtech extruder on stock X axis or Bear X axis needs a custom firmware: you can download it here.
If you don't know how to flash the firmware to your original Prusa, check this guide: https://help.prusa3d.com/en/guide/upgrad...
Place the steel sheet on the heated bed, if you are running a MK2.5(S) or MK3(S).
To check everything has been wired correctly and to calibrate the printer you need to run the wizard.
LCD Menu -> Calibration -> Wizard
Follow the instructions displayed on the LCD screen.
In Settings -> Temperature -> Fan speed set the value that corresponds to your most used slicer profile (min value = 0, max value = 255). For example, set it to 130 if you print mostly PETG and 255 if you print mostly PLA.
Run a PID calibration by selecting, Calibration -> PID calibration, from the menu.
With a new extruder you will need to recalibrate your extrusion multiplier (per spool). Follow our guide here: 8. Extrusion multiplier and filament diameter
Congratulations, you have finished! You can now relax and enjoy your new frame.
Do you need a spool holder? Check our selection of optional parts made by the community.
Happy printing :)
